Old May 1, 2008, 08:15 AM
Dashock's Avatar
Default Fans for WC and tubing
Alright heres the problem first off DC is out of the 7/16 tubing of swiftech im gonna try calling them today and see what they can do. Any recommendation of another one or is swiftech tubing the best.
2nd Fans im most likely going to use 4 fans im buying the Swiftech Double rad with intergrated resvoir.
Should i use Noctua NF-P12 120mm - Lots of reviews saying its good
compared to the Scythe Ultra Kaze 120MM High Static Pressure Silent Fan 38MM 1000RPM 44.4CFM 19.8DBA
Scythe a lot cheeper but i wanna keep my temps low as well as my noise so any suggestions?
Old May 1, 2008, 09:38 AM
magictorch's Avatar
http://www.ncix.com/products/index.p...cture=Swiftech
the tubings in stock at NCIX-you always price match teh other WC parts their and buy as one order. I use two NF-P12 fans and they work very well. I havent used the scythe fans so cant compare-i think the ultrakaze are a good competitior??
Old May 1, 2008, 10:20 AM
Cptn Vortex's Avatar
I would definitely choose the Scythes over the Noctuas. They are MUCH better for watercooling Rads.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 2, 2008, 07:48 AM
Dashock's Avatar
then how come the tests and reviews they did worse???
Old May 2, 2008, 09:03 AM
magictorch's Avatar
you couldnt stick the links could you-quite interested....although Vortex know his stuff
Old May 2, 2008, 02:00 PM
MpG's Avatar
MpG MpG is offline
The review he's probably referencing is THIS ONE. More specifically, in the rad test, a single Noctua was actually posting lower temps than TWO Ultra Kazes. I'm sure everyone's mileage may vary a little, but those are some pretty damning numbers.
Old May 2, 2008, 03:00 PM
Dashock's Avatar
yep MPG is got it right i didnt post the link because it the Noctua review was done here and most people answered it my bad but yea it showed one Noctua beating out the Scythe so i was wondering.
Old May 5, 2008, 10:13 AM
Dashock's Avatar
Well i ended up buyin the Noctua based on reviews on such i hope i made the right choice
