Old January 28, 2014, 09:23 AM
Trial Member
Default Water cooling 4770k and GTX760
Hello to all.
Here is a test that looks to me interesting with recent products, such as those of "Martin":
Alphacool NexXxoS UT60 360 Radiator | martinsliquidlab.org
Fan Testing Round 12 | martinsliquidlab.org
However I do not see results / graphs and I wanted to compare the results with those of Martin.
I am new to the PC world, such as WaterCooling, and I thought about starting with a good base of information gleaned from this site.
If any of you can do something for me, will be a great pleasure.
Thank you in advance.
So :
I thought start from a Fractal Define R4 DESIGN and a Swiftech H220 and improve it...
But, following the Martin's tests, I want to add 2 radiators from Alphacool to the loop - 1 MONSTA 240 in front and 1 MONSTA 120 in the bottom - with "Gentle Typhoon AP-45 2150RPM" fans in push -pull for each radiators.
On an Intel i7 4770K Haswell and a GTX 760 (on a sabertooth Z87).
What do you think about it?
Old February 8, 2014, 03:10 AM
2 rads for a cpu and 1 gpu? Unless you plan on going SLI in the future it may be a bit of overkill.
Old February 8, 2014, 09:10 AM
Birk's Avatar
I was actually running a 2500k and 2 7970s off a single 240mm XSPC thin rad in a Fractal Design Arc Midi R2
Old February 8, 2014, 09:55 AM
Bond007's Avatar
Never double checked, but I am pretty sure gentle typhoons are discontinued.
[WTB] WTB/WTT for R280x/7970/GTX680/GTX760 Chumpy Buy/Sell & Trade 0 January 12, 2014 07:19 PM
[FS] Gaming Rig |i7 2600k 4.8Ghz|Gtx760 SLI |SSD| 3Dmark11-P15392 kenken3686 Buy/Sell & Trade 11 November 13, 2013 05:41 PM
Can't decide! Case, Water Cooling/air cooling Birk Cases 2 September 11, 2013 07:44 PM
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
