Old January 9, 2014, 02:37 PM
IITSChiefII's Avatar
Default Feser One Coolant after 2 1/2 years usage
So I decided I needed to redo my loop itís been a long time. I have been using Feser one UV blue coolant for 2 years 5 months without draining it once, the bottle says maximum 1 year. Iíve only topped up the liquid a little about 2 times a year 4 times total to account for evaporation.
The loop consisted of Koolance 370 cpu block, Dander Den monsoon reservoir, Phobya 200mm radiator V1, 6 Bitspower nickel plated compression fittings, feser clear tubing.
I really liked the UV glow the feser coolant gave but it wore off really fast and the coolant massively stained the tubing, but it did do its job and prevented corrosion.
The coolant left a ton of gunk on the microfins of the Koolance 370 block, I was expecting this to happen though. There was also massive plasticizer leaching it was everywhere.
I have switched back to Koolance coolant my favorite, and Iím trying out Primoflex advanced LRT clear tubing so far I really like the tubing.
The only part of the loop that had corrosion was the bitspower compression fittings the corrosion was beside the oring on the G1/4 threads the corrosion was very minimal. I cleaned them up and reused them.
Redoing my loop didnít reduce temps not even 1 degree its exactly as it was before, I guess the gunk on the microfins didnít stop enough flow or disrupt heat transfer enough to make a difference, either that or I messed up remounting my waterblock which is almost impossible with the Koolance 370. Iím still sitting at 4.5Ghz on my 3770k at 1.23v with temp of mid-high 60ís in prime. I have an itch to delid but I donít think itís even worth it. If my temps were at least 10c higher then I probably would.
Old January 9, 2014, 03:22 PM
lowfat's Avatar
The coolant didn't cause the issue. The plasticizer did.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 9, 2014, 04:33 PM
Ya man the stuff was everywhere lol, whole layer of it on my reservoir. Still the hardest thing was getting the oring back onto the Koolance 370 block lol.
Old January 9, 2014, 05:26 PM
Sagath's Avatar
This is why I just run distilled + coil now.
Old January 9, 2014, 06:19 PM
lowfat's Avatar
It will still happen with distilled. The funking in the blocks will just be clear. The only real solution is to use copper or acrylic tubing.
Queen of Dreams WIP
Big Lian Li
Complete
Old January 10, 2014, 07:00 AM
Type L hard temper copper w/ a bender. :)
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 10, 2014, 07:04 AM
Sagath's Avatar
wait, this is from the tubing not the colorant in the coolant?
Holy crap. next up. Hard piping my rig. Thats insane!
Old January 10, 2014, 08:58 AM
stoanee's Avatar
How about stainless?......
heatware
Old January 10, 2014, 07:51 PM
Stainless works fine but typically used for high pressure. The benders aren't cheap either.
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 10, 2014, 08:02 PM
stoanee's Avatar
Certain people who "make beer" may have access to this equipment.......
heatware
Coolant Question lxxl Water Cooling 14 October 4, 2013 10:05 AM
Spilled Feser One Coolant AmuseMe Water Cooling 10 November 9, 2009 09:18 PM
Feser One Blue UV Coolant element291 Water Cooling 23 October 5, 2009 11:43 AM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
What is your coolant of choice? Babrbarossa Water Cooling 26 April 14, 2007 07:22 PM
