-   -   Pump outlet/drain question (http://www.hardwarecanucks.com/forum/water-cooling/64753-pump-outlet-drain-question.html)
HiTi December 22, 2013 07:03 PM
Probably an easy or silly question, but here goes..
I've got a d5 vario with a ek top in the build I am slowly doing and am looking to install a drain
My question is, if the pump top has 2 outlets, can I use one of them to exit to a drain plug? And the other to continue the loop obviously
I can't see why not, but thought I should ask just in case
Thanks
lowfat December 22, 2013 07:18 PM
Yes you can. I'd suggest using a ball valve fitting.
clshades December 23, 2013 12:43 AM
you can use a port out of the video card too... lowest is bestest.
HiTi December 23, 2013 04:17 AM
Thanks! Figured it wouldn't be an issue, I'll hopefully update my build photos today to show where input it
