Old December 11, 2013, 11:25 PM
Fudd Rucker's Avatar
Default Radiator
Hi
Collecting all the bits for my custom loop , and I'm wondering - would a 240mm rad and 120mm rad suffice for the 2 680s and an i5 4670k?
Was planning on doing the loop in the following order :
Pump -> CPU -> 120mm rad -> GPU's -> 240mm rad -> reservoir (planning on a pump/res combo)
I could do a 280mm top radiator, but will that extra little bit make that big of a diff?
Im not going for killer clock speeds as I would like to keep the temps on the GPU's a little more even and to eliminate the god awful noise of the ref fans lol.
I couldnt think of something snarky or interesting to put here this time around.
Old December 12, 2013, 06:16 PM
lowfat's Avatar
What fans will you be using? Fan speed is generally as important as the number of radiators. If you are going to be using above 1500rpm you'll be perfectly fine.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 13, 2013, 11:45 AM
Using Cougar Turbines in a push config. Well planning that anyways.
Old December 14, 2013, 10:32 AM
which case and why not a single triple rad?
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 14, 2013, 12:00 PM
Bitfenix Ghost Nanochrome. Unfortunately it only has enough room for a top 280mm/240mm rad and a 120mm rear rad. I cant seem to get my cards to oc worth a damn at this point, so now its about keeping them quiet more than anything.
My custom loop wasn't really planned at all, but my 3 blocks I needed came up really really cheap and I figured I wouldn't pass up the opportunity for what I thought would be a cheap loop lol. I would prefer to keep this case as its exactly what I wanted in a case feature and look wise.
Old December 14, 2013, 12:20 PM
lowfat's Avatar
A 2x140mm radiator is nearly as good as a 3x120mm. Do you already have the radiators and fans?
Queen of Dreams WIP
Big Lian Li
Complete
Old December 14, 2013, 12:32 PM
Have the fans, waiting until after xmas to get the rads. Was looking at a Stealth GT 280mm with a double wide 120mm for the rear.
Edit - Anyone know if the Swiftech compression fittings are any good? I would assume a fitting is a fitting providing it doesn't leak and does with what's supposed to do?
Old December 14, 2013, 01:03 PM
I personally haven't had any trouble with any new fittings. I have bought some shitty used 2-3 way swivel 90* and 180* in the past though.
These are my favorite kind of 90's I find them easier to tighten.
90 Swivel Elbow Lok-Seal? adapter - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 14, 2013, 02:04 PM
lowfat's Avatar
Definitely do not buy the Stealth 280. They absolutely require high speed fans to perform worth a damn. Anything less than 2000rpm and the radiator will not perform well. If you want a slim radiator use XSPC AX or EX 280s or an HWLabs SR1 if you can fit a thicker radiator.
Queen of Dreams WIP
Big Lian Li
Complete
Old December 14, 2013, 06:27 PM
Measured it out, the SR1 280 will fit in the top compartment of my case with room to spare! The downside to that radiator is that I don't see it on Dazmode's site, and I would prefer to order the rest of my gear from there at once. Im guessing he must have something along those lines fir a radiator.
Radiator yycraven Water Cooling 7 March 5, 2013 10:12 PM
Need someone who has a 120.2 Radiator AmuseMe Off Topic 0 August 13, 2012 06:34 PM
Should I add another radiator or will it be enough? siegfx Water Cooling 18 February 8, 2012 08:56 PM
Is one radiator enough oksir Water Cooling 12 March 25, 2011 12:48 AM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
