Old November 27, 2013, 05:48 PM
Default h100 or h60
Hey Guy's,
I was thinking of picking up one of these two on Friday. Tiger Direct will have them for 59.97 and 29.97. Is it worth it, I'm currently cooling my i5 3570k with a hyper 212+ and do not have any temp issues, just thought for the low price it's a good way to get into Water cooling.
Thoughts?
Old November 27, 2013, 06:14 PM
IRQ Conflict's Avatar
I wouldn't waste the money if your not having heat issues. The best way to get into water cooling, if that's your goal, is a custom loop. Take a look at (if you haven't already) some of the custom builds here. IMO nothing beats the look of a well thought out water cooled PC. I find that AIO coolers are great if you actually need one and don't have the time/money to spend on a custom job then fine go with it. Other than that I think it's a waste.
Old November 27, 2013, 06:34 PM
Bond007's Avatar
There wouldn't be that much of a difference over the 212. To make it worth your while you would have to go to something higher end or custom IMO.
Old November 27, 2013, 06:47 PM
Fair enough,
I don't have the funds to do a custom loop right now so I'll hold off.
Thanks
Old November 27, 2013, 11:41 PM
Unless you get a double or triple radiator, you don't see enough improvement out of the single raditor all in one loops to justify upgrading.
Corsair H100 draemn Price Check 1 September 11, 2013 04:47 AM
H100 mod lol rfglass Water Cooling 11 April 14, 2013 09:02 AM
H100......this looks bad....... jonny.nguyen2 Water Cooling 18 April 17, 2012 02:27 PM
H100 trayton Water Cooling 19 March 5, 2012 12:55 PM
