Old November 26, 2013, 02:53 PM
Default best duo thin rads
best duo thin rads? 240mm...>?
Old November 28, 2013, 02:18 PM
I heard this one Swiftech MCR220-XP "EXTREME PERFORMANCE" Radiator Series - Dual 120MM is good
but I haven't had any personal experience with this
Old November 28, 2013, 02:20 PM
lowfat's Avatar
'best' could mean so many different things. If you are going to be using high speed fans (2200rpm+) than a HWLabs Black Ice Steath. If you are using low speed fans than likely an Alphacool ST30 would be the best choice.
Big Lian Li
Forever Alone
Old December 9, 2013, 10:37 PM
Dazmode's Avatar
Sorry to disappoint, but they all come from 3 factories with different labels on it with a lot of marketing BS around.
Having said that depending of your desired fans speed, you will be marginally better with high desity-hi speed fans and low density -low speed fans combination.
Orange Build: Final Video
HTPC Build: Final Video
[WTB] WTB Thin ITX board FreeKnight Buy/Sell & Trade 1 October 15, 2013 06:45 AM
Need thin wire... biff Off Topic 29 November 23, 2010 06:16 PM
Thin Fans darksideleader Air Cooling 4 January 2, 2010 02:36 AM
Thin exhaust fan? Slik Air Cooling 5 November 6, 2009 06:26 AM
