Old November 26, 2013, 01:52 PM
Trial Member
Default Help. Need new fans for my radiator.
I have a corsair H80i and I want to get rid of the stock fans on them for reasons that are not important (I just don't like them). I'm planning to replace them with two Noctua NF-F12 PWMs in a push/pull configuration; however, I've been doing some research and fail to see the benefit of having a high/static pressure fan in the pull part of the configuration. A static pressure fan is used to prevent any air from bouncing back from the radiator and out through the spacing between the fan blanes.
Now that being said; would it not be better to have one Noctua NF-F12 PWM to pus the air through the radiator and an airflow fan like the Noctua NF-S12A FLX to pull the air from the radiator? Also, would using a pressure fan to push air really needed? Could I not just use the airflow fan in a pull only config?
I would appreciate anyone's insight; especially ifyou have lots of experience testing out these types of configuration. Thanks in advance :)
[FS] GTX560Ti 448, 120mm radiator, 120mm/200mm fans... WTB/T: Modular PSU, i5 2500k bundle wonton1017 Buy/Sell & Trade 2 June 18, 2012 05:13 PM
Low RPM fans on a High FPI radiator bigFOIG Water Cooling 12 January 10, 2012 06:32 PM
[WTB] LF: 3x12 Radiator, 1366 WB, Pump, QUIET fans, tubing, fittings, res n-sanity Buy/Sell & Trade 0 December 14, 2011 02:24 PM
Q: Radiator and Fans matari Water Cooling 5 July 13, 2011 09:00 PM
Fan Controller for Radiator Fans AmuseMe Water Cooling 13 May 17, 2010 07:10 AM
