Old November 23, 2013, 06:58 PM
Default My loop is losing water fast
I recently reroute tubes in my system, and for the last few weeks water in the loop disappears very fast, it's about 10-15mm per week I am using a dual bay reservoir.
I am using exactly the same components as before, and the 360 rad is an external backpack when I tune off the system, I can see some air in one of the tube connecting the rad and the pump, all other tubes are filled with water
so my guesses are:
1. my loop has a leak, maybe the rad (will other parts leak kills/burn the system?) but how can I know where?
I am using distill water, no color no smell
2. my system is beside the room radiator, is it possible that the heat from radiator help to steam away some
water?
3. there is a lot of air in the rad, beside what I can see from the tube mentioned above, how can I get it out?
This is my first water cooled build, so don't really have to much experience, any advise will be appreciated.
Old November 23, 2013, 07:00 PM
sswilson's Avatar
Have you been topping it up when you find it low? If you aren't seeing any water pooling / puddling my first guess would be that you've got a lot of air in your loop and it needs to be properly bled.
Old November 23, 2013, 07:24 PM
ZZLEE's Avatar
blue shop towels around and near all fittings see if anything shows up.
You may have lots off air in loop but look hard fore leaks.
Edit : water needs a piece of silver fitting with silver or a silver object in the res to stop algae growrh.
nothing to do with leak or air but will fix feuter problems.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old November 23, 2013, 08:10 PM
KaptCrunch's Avatar
I would pressure test loop @ 3psi and see if drops over night
other hear any odd noises around pump
Old November 23, 2013, 11:20 PM
just sounds like it hasn't been bled out properly.
Ixnay on the silver eh... put a half cup of 50/50 glycol in there it costs less than a silver fitting and nothing will grow ever. It is basically the same as spending 15 bux on inhibitor from any water cooling reseller except Canadian tire sells 50/50 for about 5 bux.
I've gone through the whole silver conversation in other posts and I'm not interested in going through that lesson again... adding more metals to an already mixed metal loop will only make things worse and certain kinds of nickel blocks do not play nice with silver. This is why glycol is used and one of the reasons it was invented.
Mah Rig now
Mah Rig before
My stuff for sale.
Old November 24, 2013, 05:40 AM
KaptCrunch's Avatar
Default Caution will some loose health
yes in automotive but in home heads up, get propylene glycol
caution to glycol, Ethylene glycol should not be confused with propylene the lesser poison
note: vapors are same as ingestion
any time use something read the msds of stuff
MSDS of 50/50.pdf
<H2></H2>
Old November 24, 2013, 06:40 AM
nasrott's Avatar
sounds like your just need to bleed the system as others have already mentioned, turning the case on it side, left, right idea may get the trapped air out..I usually try to get my res in a non overflowing spot and leave cover off while system is running, In the end will still be a little air in res that stays there idea..
Old November 24, 2013, 06:42 AM
"Quote This..."
LOL, why would you mix it with water first? Just put a 1/4 cup in.
Old November 24, 2013, 07:45 AM
Who said he wasn't talking about it coming pre-mixed at 50/50?
Old November 24, 2013, 10:10 AM
Shadowmeph's Avatar
I have always rapped paper towels around where any of the hoses are connected then I would jump my PSU and run the pump over night to make sure of any leaks if you cannot find any at all then maybe check the actual water blocks them selves to make sure the seals are not squished which happened to me when I pulled about a older cpu water block and cleaned it I put it back together and was about to turn on the pump and noticed tha tthe rubber seal was sticking out a a tiny bit so I unmounted the water block from the CPU and fired up[ the pump sure enough it has a very very tiny leak it took a few minutes to actually notice it even with the paper towel but it ended up being I over tightened the screw . which I have done before when putting vavle wcovers on a car many years ago I had thought that the tighter the better but what happens is that where evcr the mount bolts or in the case of the CPU block mount screws it would squish that part and create a gap beside it.
Water disappearing from loop? chrisk Water Cooling 13 August 29, 2011 12:56 PM
wow fast on water ah gingerbee Off Topic 1 December 31, 2009 07:50 AM
Water Loop enaberif Water Cooling 8 July 17, 2009 09:35 PM
Best way to add water to a loop ebdoradz Water Cooling 9 January 18, 2009 11:48 PM
