Old November 24, 2013, 01:57 PM
KaptCrunch's Avatar
Originally Posted by draemn View Post
Who said he wasn't talking about it coming pre-mixed at 50/50?
put a half cup of 50/50 glycol in there it costs less than a silver fitting and nothing will grow ever.
he was stated came 50/50
OP just close res and flip/twist computer
sortta like ball-bearing maze to bring air to rez
Old November 24, 2013, 02:23 PM
ZZLEE's Avatar
Check Rads fore punctures or leaks usualy from a bolt being tightened to much into the RAD.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old November 24, 2013, 02:59 PM
Dazmode's Avatar
Sometimes those things are hard to troubleshoot. For example if you have micro-leak in radiator body, water evaporates faster then you can see it.
Start with basics. Check out of all fittings are tight.
Orange Build: Final Video
HTPC Build: Final Video
Old November 26, 2013, 01:47 PM
I think I find the problem, one of my hose clamp is not tightened properly, there is a tiny tiny gap between the tube and the barb
my theory is that tiny gap helps the water evaporate from the loop
I added water again yesterday, and I will if there is still massive water lost in the loop
my appreciation to everyone who replied, thanks.
Water disappearing from loop? chrisk Water Cooling 13 August 29, 2011 12:56 PM
wow fast on water ah gingerbee Off Topic 1 December 31, 2009 07:50 AM
Water Loop enaberif Water Cooling 8 July 17, 2009 09:35 PM
Best way to add water to a loop ebdoradz Water Cooling 9 January 18, 2009 11:48 PM
