Old November 21, 2013, 04:28 AM
Prolab's Avatar
Default Phobya 480 XT bleed port
Can I use the bleed port as a connection just like the 2 regular ports?
Or is this strictly a bleed port?
Thanks
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old November 21, 2013, 07:51 AM
lowfat's Avatar
If you use both inlets and both outlets, sure. But that would be a parallel loop and you'd need two pumps. One in each 'loop'. IMO it would be a rather poor idea.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old November 21, 2013, 11:15 PM
Prolab's Avatar
Hmm, Im talking about the single port on the rear of the rad.
That's the one you meant right?
Gaming Rig:
HTPC Rig:
Old November 21, 2013, 11:21 PM
lowfat's Avatar
Actually then no. It can be used for bleed or draining. That is about it.
Queen of Dreams WIP
Big Lian Li
Complete
Old November 25, 2013, 03:01 PM
Prolab's Avatar
I figured i can't do that.
Thanks!
Gaming Rig:
HTPC Rig:
Old November 25, 2013, 03:39 PM
KaptCrunch's Avatar
if want to run like a T set-up this is the way to do it for bleed hole is negative pressure for return feed
if switch flow will be positive output
Old November 26, 2013, 01:16 PM
Prolab's Avatar
Ok, thanks for the idea!
Gaming Rig:
HTPC Rig:
vertically mounted 360mm rad - does not bleed geoc Water Cooling 15 November 21, 2013 06:11 PM
Phobya 200mm rad/pump/block and tubing package and gpu HiTi Price Check 1 August 26, 2013 09:05 AM
Backlit bleed, how much is too much? Valamyr Display Units 10 March 27, 2013 08:28 PM
phobya wacoolt Jaydu Cases 4 October 27, 2012 03:53 PM
[WTB] phobya 140mm radgrill krajee Buy/Sell & Trade 1 January 31, 2012 04:57 AM
