  #21 (permalink)
Old November 20, 2013, 05:42 PM
rjbarker's Avatar
^^^ Yeah I'm thinking the same thing Hero...bottomline I think 4.8 - 4.9 ghz is my Max 24/7 Clocks anyhow, for Benching I can push the 3930K to 5.1 Ghz and still dont run into Temp issues...so cant really see the benefit throwing the CPU into the Loop, its fine on the H320.
As for the GPU's, certainly under water is what these bad boys need ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #22 (permalink)
Old November 24, 2013, 06:57 PM
rjbarker's Avatar
Hey guys....so I'm thinking 1 x 480 and 1 x 360 Rads for my 3930K, and 2 x 780TI's....what would your opinons be for these 2 Rads:
Black Ice SR1-360 Silent Revision 1 Triple 120mm Fan 2-ROW Radiator G 1/4IN Threaded Black Carbon
Black Ice SR1-480 Silent Revision 1 Quad 120mm Fan 2-ROW Radiator G 1/4IN Threaded Black Carbon
this for pump
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Still looking at Reservoir...and Tubing size...fittings (think I've made up my mind Compression Fittings)...
MARK 11: 32.530
  #23 (permalink)
Old November 25, 2013, 11:39 AM
nasrott's Avatar
I'd consider going with a dual reservoir and pump setup, is what I Am considering with a similar setup.
  #24 (permalink)
Old November 25, 2013, 11:53 AM
hero1's Avatar
Those rads should be good enough for you. The 360 up top and 480 at the bottom. That pump will be more than enough to go through the whole system and a 250ml reservoir will also do. For tubing, I'd suggest a 3/8" ID x 1/2" OD, more than enough and add compression fittings of the same size.
  #25 (permalink)
Old November 25, 2013, 11:57 AM
lowfat's Avatar
I think two pumps (and especially reservoirs) is mostly a waste of money.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #26 (permalink)
Old November 25, 2013, 11:59 AM
hero1's Avatar
That's why I was quick to tell rjbarker that 1 pump and 1 res is more than enough.
  #27 (permalink)
Old November 25, 2013, 12:42 PM
rjbarker's Avatar
hero n lowfat...thanks guys, thats actually what I was thinking was the 360 Rad up top and the 480 Rad down below....that way I still have access to the connectors on my FC9 Fan Controller from up top (otherwise te 480 would cover it and the ittle connectors are a bit of a pita if you cant see em ;)
Dont know anything about which sizes of tubing is optimal, bu if you guys suggest 3/8" inside and 1/2" outside so be it....
Thanks again...still looking at after New Years, bu maybe purchasing parts as I see them.....looking out for 780Ti Full Water Blocks..
MARK 11: 32.530
  #28 (permalink)
Old November 25, 2013, 12:55 PM
SugarJ's Avatar
The difference in tubing size between 3/8 and 1/2 ID has been shown to be negligible. I like fat tubing, so I use the bigger size but it's your preference. 3/8 is certainly more popular.
Definitely go compression fittings. They're worth the money. That pump is what I use, it's powerful enough to drive any loop.
If you go to a tube reservoir, you'll need a pump top so you can screw fittings into it, or get a top/res combo. They come in both bay and tube styles.
  #29 (permalink)
Old November 25, 2013, 02:30 PM
rjbarker's Avatar
Sorry Gord.....dont quite get what you mean here
MARK 11: 32.530
  #30 (permalink)
Old November 25, 2013, 03:00 PM
Prolab's Avatar
What he meant was, aftermarket pump top has a G 1/4 threads. So you can use any fittings that has a G 1/4 thread and go nuts. As well, most tops has different IN/OUT ports so you can figure out the best way to run your line.
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
GTX 780ti opinion ! Gordon freemen Video Cards 5 November 7, 2013 04:26 PM
