  #71 (permalink)
Old June 4, 2014, 02:59 PM
rjbarker's Avatar
I've also got 3 x Penetrators 120mm up front as Intakes, so in total:
Top Rad 4 x 120mm Intake
Bottom Rads 5 x 120mm Intakes
Case Front 3 x 120mm Intakes
Single 140mm Exhaust Top / Rear........definitely Positive Air Flow and you can "feel" air being pushed out of every vent n orifice within the Case ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #72 (permalink)
Old June 29, 2014, 06:52 PM
Astaroth's Avatar
What if you're using a rear rad and top rad?
  #73 (permalink)
Old June 30, 2014, 04:11 PM
AmuseMe's Avatar
I do not have time to go through the eight current pages on this topic, but I want to point something out. I'm an apprentice Millwright Mechanic, and a lot of what we cover has to do with refrigeration, cooling, heat exchangers etc. I'm also a post radiator builder and industrial cooler fabricator. With that said, I am not an engineer, so just take what I say with a grain of salt.
Even though a fan can both push, and pull airflow, the blades of the fan, are designed for a specific orientation. Some fans are made to pull, some are made to push. It all depends on the contour of the blade, the number of blades, rotation, and pitch.
So while one fan may be awesome at pushing air into a case or through a radiator, it may not be as beneficial or as smart, compared to using one that was made more pulling, to pull.
Get what I mean?
  #74 (permalink)
Old July 4, 2014, 01:40 PM
Prolab's Avatar
I agree, if we're talking about commercial/industrial applications.
But, with computers in general (for mainstream anyways) most fans are designed to push air through something. Whether they do it efficiently is another story.
There's a handful of fan manufacturers that do design their fans with function rather than bling.
But with the popularity of AIO and WC'ing lately - I think that might change. Well, hopefully it'll change.
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
  #75 (permalink)
Old July 4, 2014, 01:48 PM
Get what I mean?
With fans only an inch apart I reckon the extra fans help with static pressure against the rad fins. You are absolutely correct about the fans and I highly doubt the computer fans doing the pulling are working as efficiently as the ones pushing.
It's hard to say without talking to the guys that engineer these fans because some fans push in and some fans pull out in very case we buy. I can say for certain blowing more air into a case is better than trying to suck it out.
Mah Rig now
Mah Rig before
My stuff for sale.
  #76 (permalink)
Old July 4, 2014, 03:47 PM
rjbarker's Avatar
^^ For what its worth do you guys recall seeing the video Linus has out showing push n push / pull etc...? If I recall after all his testing the Push / Pull set-up with Corsair SP's as push and Corsair AF's as pull on the same Rad was the most effective for heat exchange....all fans running at equilivant RPM...point of it was not how the Corsiar Fans performed but whether mixing SP and AF was smart...this set up performed better (by a small degree or 2) vs all SP or all AF Fans...
MARK 11: 32.530
  #77 (permalink)
Old July 7, 2014, 09:09 AM
AmuseMe's Avatar
I'd love to see a watercooling fan like some of the ones I work on, with adjustable blades. Highly impractical for computer use, and probably fairly hard to make in a 120mm size, but they are neat.
In the summer we pitch the blades higher, and move more airflow. The make more wind noise and require more HP from the engine, but computer fans are electric, so noise is the only issue.
Then again, I'm sure these fun manufacturers have done their home work, and make them the way they do for a reason.
  #78 (permalink)
Old July 7, 2014, 09:26 AM
sswilson's Avatar
So it's just a manual mechanical adjustment like rotating over one lug nut? That's kinda neat... I'm used to seeing complex arrangements for pitch adjustment on props / blades / rotary wings but had never considered just a straight manual adjustment. It'd probably be prohibitively expensive though.
With price in mind, how about matched push / pull sets of fans instead? No reason why they couldn't engineer a pair of fans that would compliment each other in a push/pull config at a reasonable markup for the convenience of not having to figure it out yourself.
I know it wouldn't be a perfect match unless it was tuned for a specific rad profile, but you'd think that even a generic tuning would be beneficial.
  #79 (permalink)
Old July 7, 2014, 07:20 PM
I'm sure they would sell a lot of those Wilson... I would definitely pay money for fans designed like you are suggesting.
Mah Rig now
Mah Rig before
My stuff for sale.
  #80 (permalink)
Old January 9, 2015, 12:52 PM
Cptn Vortex's Avatar
Just seeing this threat now, good info. I currently have my top 320 RAD set as Exhaust with push/pull fan setup. I think for the sake of results I'll do some benchmarking tonight with the current Exhaust setup and then swap the fans over to intake, to get some good comparison results in my case. I believe my case is currently a negative pressure, so it will be interesting to see the difference the change to positive goes.
Current setup :
Intake : 1 x 230mm, 2 x 120mm x1800rpm
Exhaust : 3 x 120mm x1000rpm push/pull, 1 x 120mm x1000rpm rear
PSU has isolated intake/exhaust
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Completed lowfat's Big Lian Li. lowfat Case Mods, Worklog & Gallery 558 March 10, 2016 04:12 PM
Hardware Canucks welcomes Lowfat as our newest Moderator! Soultribunal Site Announcements 74 January 27, 2013 04:51 AM
Completed lowfat's Tecnofront HWD bench table *big pics* lowfat Case Mods, Worklog & Gallery 67 October 6, 2010 08:35 AM
Where's Lowfat? Liu Kang Off Topic 12 July 6, 2009 05:32 PM
