  #41 (permalink)
Old November 14, 2013, 10:13 AM
Slik's Avatar
Here's a pretty good guide..Guide to proper case airflow design - techPowerUp! Forums Worth a read.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
  #42 (permalink)
Old November 14, 2013, 10:22 AM
"Oct 24, 2007, 06:58 PM"
In the last 6 years cooling methods, case design, and fans have changed in a lot of ways that experimentation is better than what may work for another person.
  #43 (permalink)
Old November 14, 2013, 10:28 AM
Birk's Avatar
2007, were we still not seeing a lot of rounded and sometimes still traditional IDE cables at that time?
  #44 (permalink)
Old November 14, 2013, 11:20 AM
Supergrover's Avatar
Originally Posted by lowfat View Post
His VRMs are definitely not 128C. 128C is just is what is shown if it can't read anything. The VRMs would blow up well before reaching those temperatures.
Pretty easy to tell that it isnt a correct reading......... the idle is the same temp.......... So it is either a false temp or his VRM's are not heating up at all under a load.
IMO Common sense right there.......
R.I.P.
  #45 (permalink)
Old November 14, 2013, 11:32 AM
Slik's Avatar
Air moves pretty much the same today as it did in 07. Obstacles notwithstanding.
  #46 (permalink)
Old November 14, 2013, 11:34 AM
Air moves the same yes. But the way air moves has changed. Fan blades, Pitch of blades, Radiators and etc all change how air flows.
  #47 (permalink)
Old November 14, 2013, 04:26 PM
Zer0's Avatar
With my CPU only loop, I can confirm that intaking cool air from the top and blowing across the rad into the case yields better temps than exhausting warm air through through the top. I've tried with both configs and NO, my RAM and VRM don't get hot either way.
Front fan (intake), rear fan (exhaust), top rad fans (intake):
  #48 (permalink)
Old November 14, 2013, 04:48 PM
"Quote This..."
That would make sense as your fans would be in a pull configuration if you were exhausting out the top. Not as good air flow.
SWEET RIG BTW!
  #49 (permalink)
Old November 14, 2013, 07:00 PM
AmuseMe's Avatar
And Squee, I didn't mean anything personal about my post. Sorry if I was offensive mate.
  #50 (permalink)
Old November 14, 2013, 07:41 PM
KaptCrunch's Avatar
another factor is todays chips heat wattage has shrunken compared to 07 standards
Completed lowfat's Big Lian Li. lowfat Case Mods, Worklog & Gallery 558 March 10, 2016 04:12 PM
Hardware Canucks welcomes Lowfat as our newest Moderator! Soultribunal Site Announcements 74 January 27, 2013 04:51 AM
Completed lowfat's Tecnofront HWD bench table *big pics* lowfat Case Mods, Worklog & Gallery 67 October 6, 2010 08:35 AM
Where's Lowfat? Liu Kang Off Topic 12 July 6, 2009 05:32 PM
