Old October 26, 2013, 09:19 PM
Default 12-24 pump controller (koolance)
Ok so I finally got the PC up and running with no leaks (yay!) The koolance controller I've been using is not working correctly and I'm not sure if it's repairable. The dial on it speeds the pump up or down if I push on it and is really inconsistent if I actually turn the dial. I don't know if I can replace the dial on the controller itself.
I'm afraid to use it and leave the computer running incase it fails and the pump stops running.
Any suggestions as to a reliable pump controller that doesn't cost a fortune? I tried using a channel on the lamtron FC9 but it's not gonna work (on or off only).
Mah Rig now
Mah Rig before
My stuff for sale.
Old October 27, 2013, 06:03 AM
KaptCrunch's Avatar
try your good friend braineater i'm sure he can rustle up something
Old October 27, 2013, 07:14 AM
lowfat's Avatar
Have you tried contacting Koolance to see if they will replace it?
Mael
Big Lian Li
Forever Alone
Old October 29, 2013, 11:28 PM
I haven't... I bought it used off the forum so I'm not sure they'll help me out at this point. I'll check it out lowfat.
Mah Rig now
Mah Rig before
My stuff for sale.
[FS] Prices Lowered, need gone: X79 MOBO, Koolance Pump/res combo jdickie92 Buy/Sell & Trade 19 August 9, 2013 01:11 PM
hooking up a pump to a fan controller Jaydu Water Cooling 2 October 11, 2012 02:39 PM
connecting a water pump to a fan controller Corpus Masochist Water Cooling 8 August 29, 2007 09:11 PM
