Old October 1, 2013, 10:31 AM
lxxl's Avatar
Question Coolant Question
I just started watercool for my rig a few weeks ago, bought most of my stuff from dazmode, and using his PROTECTOR as coolant in my loop, which contains ethylene glycol. I am wondering if this is the best choice for my watercooling components, I want them to last as long as they can, with no clogging. I have no dye in my loop and don't plan to do it (I have color tubing).
I have nickel plated acrylic EK supremacy cpu block, I have read there was problem with the old nickel plated, so I am worry if I use the wrong coolant might affect my components.
I am fully aware of the alcohol can destroy my acrylic, so I am very careful not to have them mix together when cleaning.
if I continue to use dazmode PROTECTOR (ethylene glycol), how long before I should move it out of my loop before seeing sign of stain or any type of discoloring?
Old October 1, 2013, 11:16 AM
Birk's Avatar
Are you mixing the protector with Distilled water? I dont think you'd want to run just protector through the loop.
I used DI water and protector in my loop for 2 years with no issues after making sure to thoroughly rinse everything before the build. I would suggest tossing in a silver kill coil though. I was a bit late to the game putting one in but it was still okay.
This time around I'm running Mayhem Pastel with DI water through and not seeing much difference in temps.
Old October 1, 2013, 11:30 AM
lxxl's Avatar
Good to hear you ran well with the protector, how often do you change the coolant?
Yes, using 1 bottle of protector mixing with 2L of distilled water. I have swiftech radiators and I did 10+ rinse/shakes through with hot distilled water until all dirts are out of them.
I do not have a silver kill coil, I wasn't sure if it will affect the nickel plating on my blocks.
Old October 1, 2013, 11:34 AM
Birk's Avatar
I actually had the same coolant (topped up as it evaporated) running for nearly 2 years without a full flush. My tubing was a bit of a mess after that long but my blocks, pump and rad are all fine. My best advice would be to relax a bit once you've got it up and running. I've had loops off and on for the past 9 years and never had any issues with anything. I do know it can be a little nerve racking to start and there is always that period in a new loop that I am checking it every few minutes even after a leak test but it's very rarely any issue.
Old October 1, 2013, 11:50 AM
lxxl's Avatar
that's a long time with the same liquid, I am surprised but in a good way.
I have color tubing so I shouldn't be seeing any discoloring in them, I hope.
My system has been running for almost 2 weeks now, everything seems to be good, no leaks yet. I am still keeping my eyes on it like you said just in case of any leaks. The temps are nice compare to what I had with the All-in-ones.
Lots of money spent, and I want this to last me as long as it can, you know what I mean.
Old October 1, 2013, 11:58 AM
Sagath's Avatar
I'm running flat distilled water with no additives at all, or killcoil. Have been for ~4 years, with a flush and rebuild once about a year ago. Ive had zero issues with growth, and my system has been off and idle for upwards of two to three weeks while on vacation.
Maybe I've just been lucky, or more likely people just minimize their chances by using additives. I mean really all that happens if you run into problems is a rebuild, but obviously you want to reduce the number of times you rebuild since its very time consuming to rip off all your blocks, clean, and replace tubing.
Old October 1, 2013, 12:17 PM
sswilson's Avatar
I think using proper distilled water resolves a lot of issues folks had with earlier loops, plus the fact that blocks have come a long way.
Personally, I run distilled + a couple of drops of petra and never had an issue that wasn't based on tubing and even that was minimal.
Old October 1, 2013, 12:23 PM
Birk's Avatar
I think you're bang on here. A lot of people are intimidated to get into water cooling but honestly it's pretty straight forward, there are so many tutorials out there now to help you learn what to do and what not to do for new people who are getting into this all.
Old October 1, 2013, 12:34 PM
lxxl's Avatar
A lot of the stuff I read are older posts from 2005-2009, I am not sure if it's fully accurate since a lot of stuff have been changed/updated.
I have also seen some nasty pictures with their loop clogged up, that is the last thing I want to see in my loop.
Old October 1, 2013, 12:36 PM
Birk's Avatar
I think you'd be pretty unlucky to have that happen now.
Keep your loop out of direct sunlight also though, that is one tip that is probably still good to keep in mind.
Question about using distilled water as a coolant matari Water Cooling 12 December 8, 2010 11:24 AM
Whered all my coolant go?? Realityshift Water Cooling 9 November 16, 2009 09:56 AM
Spilled Feser One Coolant AmuseMe Water Cooling 10 November 9, 2009 09:18 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
What is your coolant of choice? Babrbarossa Water Cooling 26 April 14, 2007 07:22 PM
