Old October 1, 2013, 01:52 PM
lowfat's Avatar
I'd say 95% of the gunking in loops is caused by plasticizer being leeched out from the tubing. Rarely have I seen issues caused by bacterial growth. What brand of tubing are you using?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 1, 2013, 03:06 PM
no offence to dazmode but the protector is just glycol... you can buy a 2L 50/50 glycol from Canadian tire for the same price as the little container and mix a bit into your loop to keep the bugs from growing and reduce any metal break down on the blocks. Disposing of it later is the only issue I guess... I just keep an extra windshield washer bottle around for the waste and drop it off at a Canadian Tire when its full.
what's the best tubing lowfat?
Mah Rig now
Mah Rig before
My stuff for sale.
Old October 1, 2013, 03:32 PM
lxxl's Avatar
PrimoChill PRIMOFLEX Advanced LRT
Old October 1, 2013, 07:09 PM
Birk's Avatar
You're good.
Old October 4, 2013, 10:05 AM
lxxl's Avatar
Thanks for the info guys, unless someone is running into problems, I'll likely keep the coolant for months to come.
Question about using distilled water as a coolant matari Water Cooling 12 December 8, 2010 11:24 AM
Whered all my coolant go?? Realityshift Water Cooling 9 November 16, 2009 09:56 AM
Spilled Feser One Coolant AmuseMe Water Cooling 10 November 9, 2009 09:18 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
What is your coolant of choice? Babrbarossa Water Cooling 26 April 14, 2007 07:22 PM
