Old September 30, 2013, 07:14 AM
Default Corsair H90 or air cooler?
Hi. My next rig will be a intel i7-4770k, Asus z87 Gryphon and Sapphire 7950.
I'm thinking take a Corsair H90, or else a Noctua NH-U12S or NH-D14 (although I think that the NH-D14 is too big for the board). I will do a mild OC in future (4.2/4.4 Ghz).
I would like low temperatures and noise for some years, what are your advice, H90 or Noctua?
And in case of choice the H90, what optional fan is better and more silent than the stock fan?
Thanks u.
Old September 30, 2013, 09:38 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Either H90 or D14 will give you good results. Depending on juice you have to push...4.2 will be damn silent with either (U12 prolly do it easily as well). 4.4ghz...it depends on voltage. Either of the big boys will do it, but the H90 may be a tad louder. Honestly its hard to go wrong with the D14 for moderate high OCs. IMHO high OCs require water...dual bay water at a minimum.
By the same token...I am running a H90 on a 4670K @ 4.2ghz w/ a Noctua 140mm F14 fan and its basically silent (I dont like the H90s stock fan). So YMMV.
Old September 30, 2013, 10:23 AM
Slik's Avatar
Thanks u.
If you want a very good cooler that also does it super quiet,check the Antec 920. Canada Computers | Cooling | Antec KUHLER H2O 920 Liquid Cooling System for Intel LGA 1150 /2011/ 1155 / 1156 / 1366 & AMD AM2/ AM3/ AM2+/ AM3+ / FM1 / FM2 They are a bit hard to find. If you can't find one on line, Killswitch may have one for sale. PM him for any details etc. The Antec H20 920 really is a good and quiet liquid cooler.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old September 30, 2013, 11:36 AM
I advocate following the KISS principle [keep it simple, stupid], therefore recommend air because the performance is roughly equal and less can go wrong.
Old September 30, 2013, 03:21 PM
rjbarker's Avatar
With all the great options out there for Liquid AIO Coolers and the fact you do want to OC, take the leap to AIO.....you wont be disappointed....the days of behemoth Air Coolers are becoming a thing of the past ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 30, 2013, 04:45 PM
Those little all in one water coolers work pretty good and the best part is the heat leaving the computer more efficiently than with an air cooler.
Mah Rig now
Mah Rig before
My stuff for sale.
Old September 30, 2013, 05:11 PM
le2key's Avatar
Go with the H90. Pretty confident it'll perform better than the NH-U12S and you won't have fit issues compared to the NH-D14.
For everyone else here though, depending on the setup of your internals double tower air coolers can look pretty sweet in a rig.
Reminds me of a car engine.
Old October 1, 2013, 07:56 AM
Thanks. About the noise I'm watching in youtube a lot of pump noise problems with corsair h60/80i/100i, of corsair H90 hardly there are videos. And supposedly the pump noise problem may appear at any moment right? :S
With the noctua NH-U12S will can I do a OC of 4.0-4.2ghz with temps below 70-75º for gaming?
Anyway as I said, for now I would keep without OC and I would like have temps of 55-60º (without OC), worth the U12S for get it temps supposing the worst case of a 4770K very warm?
Old October 1, 2013, 08:44 AM
Slik's Avatar
Did you check out the Antec 920? Compared to the Corsair series,you get better cooling AND super quiet. And right now,the price is right.
Old October 1, 2013, 09:12 AM
Yes, the antec is ~$14 more expensive than h90, but in youtube I see that also have pump noise problems, and in the reviews it have 42.9db, the h90 43.1db, very similars.
About H90 I cant found videos about the pump noise of this unit, I don't know if is because it has been little sold or because work good.
cooler master or corsair psu? unc4rted New Builds 9 August 1, 2012 11:02 PM
corsair h70 liquid cooler tigerzfan4life Troubleshooting 6 February 1, 2012 08:20 PM
Corsair Hydro H70 CPU Cooler ? Rush Water Cooling 9 March 24, 2011 06:34 PM
Upgrade from ZALMAN CNPS10X Performa cooler to Corsair Hydro H70 cooler completed dosmond Water Cooling 3 September 3, 2010 02:27 PM
Corsair Hydro H50 CPU cooler FtGF Water Cooling 54 July 24, 2009 04:34 AM
