Old September 30, 2013, 05:15 PM
Bond007's Avatar
Yeah if the factory stuff is applied just use it.
Old September 30, 2013, 10:53 PM
ok guys i will not removed the preapplied :)
Old October 1, 2013, 04:39 AM
KaptCrunch's Avatar
other is get current software for Link
Corsair Link Installer RC v2.4.5065
Old October 1, 2013, 05:37 AM
Originally Posted by Dzzope View Post
Pea size is usually too much though... more TIM is just extra stuff the heat has to go through before getting to the heatsink.
You only want the smallest amount to form a seal with no gaps.
Naw a pea is just perfect. It's just enough to fill gaps. I've never had it spill over or even cover the entire heat spreader. Pea is too much if you lather it on both sides like daz does.
Are you eating GM peas???? Cuz i mean a small pea about the size of a .17 cal BB.
Thermal basics : a.k.a. What thermal paste..... BrainEater Guides & How-to's 11 October 24, 2013 07:26 PM
GTX 580 thermal paste mikellini Video Cards 13 November 17, 2010 11:37 PM
Thermal Paste killerjay_47 Air Cooling 9 March 15, 2010 02:53 PM
Thermal Paste r0k0 Overclocking, Tweaking and Benchmarking 11 February 15, 2010 11:53 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
