Old September 29, 2013, 02:56 AM
SAS SAS is offline
Default EVGA Hydro Copper GTX 780 question...
EVGA | Articles | EVGA GeForce GTX 780 Hydro Copper
I am wondering if there are any reviews on this card? I have tried to find some but I cant seem to find a propper review of the EVGA Hydro Copper GTX 780.
What OC clocks are you expected to achieve with this card? How cool will it run? etc etc.
Old September 29, 2013, 06:48 AM
This may not help but I would expect this to run as well as any water cooled gpu. You'll not see more than a few degrees difference between the various blocks on the market. Esthetics yes temps no. Search for air vs water cooled 780 reviews and you'll find answers close enough to know.
Mah Rig now
Mah Rig before
My stuff for sale.
Old September 29, 2013, 07:04 AM
lowfat's Avatar
If you are going to be increasing voltage you may want to go w/ a different block. The VRM temperature of the EVGA/Swiftech block is a good 15C higher than EK. My VRMs can get extremely hot when I crank the voltage w/ an EK block, w/ a Hydrocopper it definitely wouldn't be stable.
Stren's Titan Water Block Roundup - Page 8
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 29, 2013, 07:32 AM
KaptCrunch's Avatar
heatkiller is better on gpu in the middle of stock and ek on VRM's
Old September 29, 2013, 12:50 PM
I thought the evga (i.e. komodo) blocks had a problem with the TIM compound they used, and how it was applied, and that if you re-applied it yourself you got a lot lower temps?
EVGA GTX 780 hydro copper Spblue Water Cooling 8 June 2, 2013 08:56 PM
Two EVGA GTX 580's Hydro Copper 2's 3GB deinosaur Price Check 5 December 24, 2012 10:06 PM
EVGA GTX 295 co-op hydro copper Realityshift Water Cooling 7 April 4, 2010 08:31 PM
EVGA Geforce GTX285 Hydro Copper CasheKicker Water Cooling 4 February 28, 2009 12:43 PM
