Old September 23, 2013, 01:56 PM
Birk's Avatar
Default GPU Cooling? using same side
Just getting ready to redo my build into a midtower case, I'm used to using full tower.
I've always ran my GPU using opposite corner input/outputs Like upper left and lower right.
Question is would it pose problems to use say Upper Left input and Upper Right output leaving the two lower ones plugged?
Old September 23, 2013, 02:25 PM
sswilson's Avatar
Pretty sure that will just pass fluid right through from one port to the next without passing through the GPU block.
Old September 23, 2013, 02:34 PM
Birk's Avatar
Thats what I was thinking also. Oh well!
Old September 23, 2013, 03:21 PM
KaptCrunch's Avatar
that's if the lower ports are open
Birk its fine using the top right/left
Old September 23, 2013, 03:39 PM
SugarJ's Avatar
For most GPU blocks, as long as you use one left and one right fluid will still flow through the block.
Old September 23, 2013, 03:42 PM
KaptCrunch's Avatar
on single card
Old September 23, 2013, 03:44 PM
SugarJ's Avatar
Originally Posted by KaptCrunch View Post
on single card
Ya, I didn't think he'd be trying to cram Crossfired watercooled 6950's into a mid tower.
Old September 23, 2013, 04:41 PM
Birk's Avatar
Awesome, Thanks everyone, Do you foresee any downside to using this setup?
Old September 23, 2013, 08:48 PM
KaptCrunch's Avatar
depends on loop routing...........eliminate air traps
Diy Guide: Installing GPU Cooling fan in side panel Mnpctech Guides & How-to's 5 February 18, 2013 03:36 PM
Installing Win7 driver, 'side by side' error great_big_abyss O/S's, Drivers & General Software 2 December 8, 2012 11:01 PM
On the lighter side Dogger1 Off Topic 3 October 19, 2009 11:55 AM
VR-Zone posts side-by-side comparison of 8800s and r600s Babrbarossa Video Cards 4 May 2, 2007 08:50 AM
DX10 / DX9 side-by-side screenies for CONAN Babrbarossa Reviews & Articles from the Web 4 May 1, 2007 04:00 AM
