Old September 23, 2013, 11:02 AM
SAS SAS is offline
Default Can I fit and extra rad with this pump?
I have an XSPC RayStorm 750 RS360 (V4 Pump) WaterCooling Kit and I was wondering if I could add another XSPC EX240 Slim Line Dual Fan Radiator in the loop?
Would this be too much for this little pump? I am only for now cooling the CPU.
I know I should have gotten a D5 or twin D5 pump but when I did this then I was on a budget.
So... can this pump handle another or not?
Old September 23, 2013, 11:23 AM
lowfat's Avatar
It will handle it. Most radiators aren't very restrictive.
Mael
Big Lian Li
Forever Alone
Old September 23, 2013, 11:34 AM
SAS SAS is offline
What would be the limit of this pump?
Old September 23, 2013, 12:32 PM
lowfat's Avatar
You'd likely be able to add a GPU block and still it would be sufficient. Flow rate is generally overrated.
Mael
Big Lian Li
Forever Alone
Old September 26, 2013, 10:15 AM
SAS SAS is offline
Question:
Would I be able to add a 2 x120 rad AND a single 120 rad to my loop with this pump? I have a source that gives me a good deal on a single 120 rad as well. Can I go overkill for now and add it or will it be TOO much for the V4 pump?
Old September 26, 2013, 11:25 AM
lowfat's Avatar
I'd imagine it would be fine. If you see your temps actually going up then just pull one of them out.
Mael
Big Lian Li
Forever Alone
Old September 26, 2013, 12:38 PM
Birk's Avatar
or upgrade to a D5 if the v4 doesn't cut it
Old September 26, 2013, 01:21 PM
SAS SAS is offline
I will mostly upgrade in the future, but for now then a V$ is what I have. I am just worried that its not strong enough... you guys know if it will be ok? AS with stats and restrictions?
Old September 26, 2013, 03:34 PM
I tested a 360 rad last year for flow rate etc.... the amount of time it took to move 1 liter of water without the pump and then with the pump was a 1 second difference. So not worth being concerned about. lowfat pretty much nailed it on the head.
Mah Rig now
Mah Rig before
My stuff for sale.
[WTB] A Watercooling pump or pump res combo. Soullessone21 Buy/Sell & Trade 3 October 21, 2012 06:24 PM
Extra copy of Men of War belgolas Gaming 2 February 9, 2011 07:34 PM
What's better? Extra speakers or extra soundcard? chermesh Audio 7 January 7, 2009 01:18 PM
Extra $72.00 should ia get a better mobo or CPU BALISTX CPU's and Motherboards 10 December 8, 2008 02:19 PM
Wii Package + extra nunchuck + extra game $340 >>>> $320 ONLY!!! thatguy Buy/Sell & Trade 2 August 3, 2008 03:05 PM
