Old September 16, 2013, 11:07 AM
Coach's Avatar
Default H320 pump noise
http://www.filedropper.com/pump_1
My brand new H320 has pump noise that I am guessing is not good. If you dl that audio clip you will hear 10sec of system idle with the pump on followed by 10 seconds of system idle with the pump off. Please let me know what you think. Thank you
Old September 16, 2013, 05:19 PM
rjbarker's Avatar
Have you checked to ensure that it is "topped up" ? There is a lot of good info over at the Swiftech section if OC'ers Forum.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 17, 2013, 06:10 AM
Slik's Avatar
Go here Swiftech H220/H320 Owners' Club and scroll to about the middle of the page. Good Luck!!
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old September 17, 2013, 09:07 AM
KaptCrunch's Avatar
Default Best way to burp loop
Originally Posted by overclock.net
IMPORTANT SERVICE ANOUNCEMENT
"Here at Swiftech what we’ve been able to determine is that most of the noise that comes from the pump is due to an air bubble getting trapped in it. Here are the steps to remove this air bubble.
First, remove your radiator from your case and gently shake it. You’ll need to hold it above the pump in order to do this properly. You’ll also want your pump running while you’re doing this.
Next, gently tilt your case from side to side and from back to front to help dislodge any remaining air bubbles. You may need to do this for a few minutes to get your pump to quiet down.
If the previous step was still not successful you may need to gently squeeze the tubing above the fittings on either side of your pump. Do this very gently so that you don’t end up putting unnecessary pressure on your barb fitting elbows. This should finally dislodge any remaining air bubbles trapped in your pump.
These procedures can take several minutes to almost half an hour or more before your pump will push out the stubborn air bubble and quiet down. Once this has occurred you can then just open the fill port cap on your radiator and top off your radiator with a little distilled water."
might be impeller contact, white area is a rubbing and leaving particles (jet nozzles plug)
other thing to do is call house doctor to bring blood pressure apparatus so can
push the air to top as pic below with fill hole highest point of loop
by pumping air and pressurizing fill hole (Note Max 5 PSI with pump off) to bring up air for
fluid is heavier the gas
like when fart in a pool what way the bubbles go ?
Old September 17, 2013, 04:16 PM
tapping the rad and pump with the handle end of a screw driver works too.
Call a house doctor??? LOL!
Mah Rig now
Mah Rig before
My stuff for sale.
Completed Procyon II - 900D n Swiftech H320 rjbarker Case Mods, Worklog & Gallery 4 October 18, 2013 12:54 PM
OC'ing 3930K n Swiftech H320 rjbarker Overclocking, Tweaking and Benchmarking 6 September 14, 2013 04:10 PM
H100 pump noise SuicidalPanda Troubleshooting 6 January 10, 2012 08:15 AM
Pump strange noise martin_metal_88 Water Cooling 5 June 17, 2010 08:17 AM
Swiftech H20-220C + Coolermaster CM690 = Pump Noise! Arrgh! Nate_The_Great Troubleshooting 2 January 22, 2008 01:58 PM
