  #21 (permalink)
Old September 14, 2013, 10:15 PM
rjbarker's Avatar
+The Swiftech H320 is anything but "bunk"....No issues with noise at my end...11 - 12c drop in temps moving from H100i allowed me to puch my OC a further 200 Mhz.
Firestrike Extreme: 21.452
MARK 11: 32.530
  #22 (permalink)
Old September 15, 2013, 10:55 PM
rjbarker's Avatar
Originally Posted by Phill View Post
I just moved from a H110 to a H320. dropped 11C under load. I do not like how loud the pump is. That is my one complaint of the H320
Curious which fans you went with...the stock ones or others? I'm running 6 Noctua NF F Series push / pull, there is no way I can here my pump over my Rad Fans, even with the fans turned right down low (all my fans are controlled via the Lamptron FC9).
I was reading over on Overclockers that some guys are having issues with noisy pumps on both H220 and 320. Only a few mind you....also, what speed do you have your pump running at? Obviously having the fan Controller I didnt use the splitter that came with the H320, my pump is plugged directly into CPU_Fan Header and set up profile in the Bios.
For the most part my pump only runs at around 1800RPM but will ramp up to Max (think its around 2800 to 3000 RPM) when my CPU reaches 65c (set up in BIOS)...generally only when I'm stress testing.....18000 RPM for day to day and gaming is fine as even at 4.9 Ghz I only reach around 58c on one of my 6 Cores.
MARK 11: 32.530
  #23 (permalink)
Old February 22, 2014, 09:48 AM
alamakluke's Avatar
Hi all,
I am thinking of getting the H320 today but before I go ahead and pull the trigger does anybody know if I would be able to water cool 2 7970's as well with this cooler?
alamakluke
  #24 (permalink)
Old February 22, 2014, 11:30 AM
Fudd Rucker's Avatar
I was running a 680 with a 3930k on a H220 and it was awesome.
I couldnt think of something snarky or interesting to put here this time around.
Completed Procyon II - 900D n Swiftech H320 rjbarker Case Mods, Worklog & Gallery 4 October 18, 2013 12:54 PM
Corsair H80i & H100i Review Comment Thread SKYMTL Water Cooling 27 February 24, 2013 08:22 PM
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 07:52 AM
[FS] 12GB Corsair Dominator PC3-1600 DDR3, BNIB LG 17" LCD Monitor, Swiftech APOGEE GTZ Linus Buy/Sell & Trade 14 January 19, 2009 11:26 AM
