Old September 13, 2013, 09:10 AM
Spikemaul's Avatar
Originally Posted by rjbarker View Post
thought Id drop the $600 on the new Case n Cooler instead ;)
Pictures......I like Pictures!
Old September 13, 2013, 11:02 AM
KaptCrunch's Avatar
Originally Posted by Fudd Rucker View Post
Wow those are pretty cheap considering. Wonder if that pump has enough grunt to push through two more blocks and a rad. Are you planning on expanding on it?
basicilly its a DDC mounted 0n cpu depends on head, at 6watts guessing 1-3ft max
Old September 13, 2013, 02:45 PM
lowfat's Avatar
Definitely not. The pump isn't anywhere near as powerful as a DDC.
Mael
Big Lian Li
Forever Alone
Old September 13, 2013, 03:39 PM
rjbarker's Avatar
If I decided to go with Loops Id likely ditch the AIO altogether and do it custom. Hence the 900D ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 13, 2013, 05:19 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
It uses an modified Apogee Drive. I dont know if its the Apo 1 or newer Apo 2. If it is the Apo 2...its a modified DDC. Probably not as powerful as a std DDC as it has been tuned for lower noise operation.
Old September 13, 2013, 05:56 PM
Coach's Avatar
I just moved from a H110 to a H320. dropped 11C under load. I do not like how loud the pump is. That is my one complaint of the H320
Old September 13, 2013, 07:35 PM
KaptCrunch's Avatar
to clarify like a DDC concept for they are 10 watt units, so yes weaker
Old September 13, 2013, 07:38 PM
KaptCrunch's Avatar
what kind of noise ? hum, squeal !
  #19 (permalink)
Old September 13, 2013, 08:32 PM
Coach's Avatar
More like a hum
  #20 (permalink)
Old September 14, 2013, 03:11 PM
Trial Member
Thinking of upgrading from My H100 to a the H320 with another 120 mm Rad on the Rear Exhaust thoughts ? Heard mixed reviews on the 220 so wary on the 320 (judging by the few posts i have seen here it looks promising .. looking to hit around 5 Ghz Range)
H320 is around 169.99 @ ncix right now plus the cost of another 120 mm rad and tubing and barbs
Thoughts folks to Buy or not to buy (Support a family of 6 on 1 income so very wary of buying something if its bunk)
Currently running
4770k @ 4.5 GHZ
Z87 Gigabyte UD3h
1 Asus GTX 660 OC DCU ii 2 GB GPU
32 GB ripjaws Z ram in XMP @1600 Mhz
1 Crucial M4 SSD
1 3TB Seagate (game drive)
1 1TB Seagate Capture HDD
1 500 GB My Book Back up Drive
Cooler Master HAF EATX Case
Completed Procyon II - 900D n Swiftech H320 rjbarker Case Mods, Worklog & Gallery 4 October 18, 2013 12:54 PM
Corsair H80i & H100i Review Comment Thread SKYMTL Water Cooling 27 February 24, 2013 08:22 PM
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 07:52 AM
[FS] 12GB Corsair Dominator PC3-1600 DDR3, BNIB LG 17" LCD Monitor, Swiftech APOGEE GTZ Linus Buy/Sell & Trade 14 January 19, 2009 11:26 AM
