Old September 8, 2013, 06:40 PM
r0k0's Avatar
Default Mayhem Aurora Cleaning
OKAY !
so yeah tried out the Supernova... lasted 4 days.. now I want to clean it out
any tips on how to clean it properly ?
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old September 9, 2013, 12:06 AM
Bungwirez's Avatar
(courtesy Bartacus Blood red noob build! - Page 74 )
HomeDepot plus a few thread reducers to get G1/4.
otherwise, most by most accounts from other users, dissemble your rig...
Old September 9, 2013, 05:52 AM
KaptCrunch's Avatar
install after the pump, push side not suction
Old September 16, 2013, 06:31 PM
r0k0's Avatar
I have almost no more crystal, this will be useless, I meant if theirs something I can use to clean inside the rads, tanks, tubing to clear away all the stuck on crystal ? like Javex or such product that will not harm the system but clean it away or make them unstick to clear out and go back to 0
Old September 17, 2013, 04:17 PM
run water through it man... seriously. I like the filter idea tho!
Mah Rig now
Mah Rig before
My stuff for sale.
Old September 22, 2013, 08:33 PM
r0k0's Avatar
Ok so my koolance rp-452x2 is full of the crystals, i've tried running boiling water threw it and it still wont remove itself, took it apart to clean with a towel and i cant get everything around the cracks and junctions
If i had my computer i could upload it but i cant since i'm on my phone, unless someone sends me their email so they can post it for me
Old September 24, 2013, 02:26 PM
Bungwirez's Avatar
serious bummer. have you got a waterpik? or maybe even blow it out with a compressor?
wish I could have stopped you before.... sorry man.
Old September 24, 2013, 02:48 PM
r0k0's Avatar
What's a waterpik ?
Old September 24, 2013, 05:29 PM
the same thing dentists use to clean your teeth with. Low powered water jet.
Listen man... you need to slow down a little and think things through before you cause more issues with your water cooling setup.
I don't know who told you to use boiling water but I highly suggest you NOT do that again. This equipment is not rated for boiling water and could seriously damage it if you haven't already. You will simply need to flush water through out... and by flush I mean continuous uninterrupted flow of water... just use tap water until its flushed out then flush it again with distilled.
The threaded fittings are standard throughout the plumbing industry so if you need to fabricate something from the plumbing store or hardware store then that's what you do. Standard kitchen taps have an aerator that will unscrew from the tap head. You can attach a hose adapter and some fittings to a compression fitting with some tubing *buy some cheap shit from the hardware store* and run water through it for 10-20 minutes and as high a pressure as you can deal with. Pipe another tube from the outlet into the drain. Do this with all your water blocks.
If you want to use warm water go for it but I wouldn't run sustained hot water though any of the blocks... the tubing doesn't deal with hot for very long.
Something like below.
The blocks you'll need to take apart and clean with a tooth brush and put them back together... carefully and patiently
Mah Rig now
Mah Rig before
My stuff for sale.
Mayhem Aurora Mixing r0k0 Water Cooling 13 September 9, 2013 04:38 PM
[WTB] Mayhem RED Dye r0k0 Buy/Sell & Trade 1 August 28, 2013 08:34 PM
Mayhem Dye with Fesser cooling fluid (Dazmode protector) magiwizard Water Cooling 5 October 31, 2012 11:45 AM
WIP Mayhem Inc. Overclocking.ca Case Mods, Worklog & Gallery 13 July 6, 2012 09:52 PM
Stacker 810 vs Aurora 570 enaberif Cases 22 October 18, 2007 06:10 PM
