Old August 20, 2013, 03:01 PM
Default water cooling
years ago I had a sys that had water cooling sys in in but one of the lines leaked a bit of water and fried the sys I am thinking of converting back to a water cooled sys but don't know much about how to prevent that from happening again trying to decide if it is worth it my sys has some heat related problems now and is not overclocked and if so where to begin the last one was an off the shelf cooling sys.
any help would be appreciated.
Old August 20, 2013, 03:12 PM
CPU only? Get a Corsair unit.
Old August 20, 2013, 05:02 PM
What type of equipment where you using, water cooling wise?
Old August 21, 2013, 07:44 PM
as of right now I think only the cpu not sure if I should do the gpu also or not
Old August 21, 2013, 07:48 PM
it has been so long ago I am not sure but I think it may have been an earlier version of the Thermaltake big water series.
Old August 22, 2013, 02:53 AM
Bungwirez's Avatar
many many improves since the big water. but if just for CPU, most easy and effective is H100
Old August 22, 2013, 04:49 AM
KaptCrunch's Avatar
echo Corsair
Mac Pro mod water cooling marquee Water Cooling 6 January 17, 2013 07:11 AM
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
Water Cooling Help jaetot328 Water Cooling 6 November 9, 2011 04:04 PM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
