Old August 20, 2013, 09:48 PM
wayy ahead of ya haha
Old September 23, 2013, 12:09 PM
Well I ended up doing some test runs with the top fans as intakes and exhuast.... 5 degrees lower on my GPU with the top fans as intakes...
Old September 23, 2013, 12:15 PM
lowfat's Avatar
I always have my top fans as intakes as well. Always has performed better for me.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 29, 2013, 02:52 PM
Same, top as intake. you want the coldest air going threw your rad and pre heated case air isn't the best.
I tend to exhaust out the bottom, hot air does rise but it takes little to no effort to push that air where ever you want.
Old September 29, 2013, 05:49 PM
makes sense... i'll have to give it a try. Exhausting out the just the rear then?
Mah Rig now
Mah Rig before
My stuff for sale.
Old September 29, 2013, 08:48 PM
Yeah I changed my rear fan to exhaust and going to change the bottom to exhaust and leave front and top as intakes
Old October 5, 2013, 04:59 PM
rjbarker's Avatar
Yep same here.....6 fans push / pull "intake"...also 3 fans front intake...1 fan top back 140mm exhaust....for me its counter productive to blow warm air over a Rad to cool CPU....also as intake you provide air blowing onto your Mobo, Chipset and Ram....
Positive Pressure works best for me...keeps my CPU OC in check as well as my 3 GPU's happy....wayyy less dust as well....
Air IN from the front,bottom [if there's an opening],side [if there is one],and OUT,or exhaust through the rear and top of the case. Every one of the "botique" high end builders recommend that configuration.Google that info and I'm sure you will see the vast majority of enthusiast rigs are designed that way.
^^^^ Nope...its actually split closer to the middle 50 / 50...the intake / exhaust argument as positive pressure vs negative pressure has always been a personal choice and arguments in either arrangement.
Enaberif nailed it.....equal intake and exhaust means neither positive nor negative pressure......imo most case have enough natural vents and seams etc that positve pressure effectively forces air out these vents...with good positive pressure try holding a tissue to a vent on the back of your case.....see the air being forced out?!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 5, 2013, 06:27 PM
Generally a positive pressure environment is gonna be better IMO. Not sure why I never considered reversing the rad though as it makes perfect sense. This is how we cool our vehicles and makes a for a interesting idea to perhaps add 140mm to the top of a case above a mobo and turn the rad on it's side. Be a big assed case tho. :-)
Mah Rig now
Mah Rig before
My stuff for sale.
  #19 (permalink)
Old October 5, 2013, 07:35 PM
rjbarker's Avatar
Gonna be switching out the stock Corsair Fans that came with the 900D with 4 x Silverstone Penetrators......fvck, sounds like porn!!!! All 1500 RPM Intakes w blue LED's.
The Noctua NF F Series are great for push / pull on the Rad, very effective.
The top back 140mm exhaust (Stock Corsair), I'm swapping out with a Gelid Wing 140mm with blue LED.
MARK 11: 32.530
Do i need intake fans? KSiG Cases 9 September 29, 2012 09:00 PM
bottom-intake fans and cable management Generic User #2 Cases 3 September 25, 2012 09:38 PM
Got a too many fans for my case, help me pick which to keep 0o0 Air Cooling 8 March 19, 2010 07:52 PM
Case fans to MB or PSU? ontariodude Guides & How-to's 14 September 28, 2009 01:31 PM
Case Fans? chouchou Air Cooling 3 October 24, 2008 06:49 PM
