Old April 28, 2008, 12:09 PM
Dashock's Avatar
ahh thanx ngear cheers
Old April 28, 2008, 01:01 PM
Dashock's Avatar
Alright orders all done if anyone has any last minute add ons i should consider by all means otherwise im placing the order tommorow cheers!
Old April 28, 2008, 01:21 PM
Supergrover's Avatar
I hate plastic barbs/fittings myself grab 2 more sets for the res and rad. Other than that looks good.
R.I.P.
Old April 28, 2008, 01:25 PM
magictorch's Avatar
remember to NCIX price match with DC prices! should take about 20 or so dollars at least off the total. or just go with Dc.
Old April 28, 2008, 01:34 PM
Cptn Vortex's Avatar
He would only need 1 more set of Metal barbs, as the Res is integrated into the RAD! But the plastic perform the same, the metal ones are just a little nicer looking and a little more forgiving to work with.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 28, 2008, 02:22 PM
Dashock's Avatar
Any purticular metal barb i should buy or something?
Old April 28, 2008, 02:32 PM
Dashock's Avatar
And btw how would ncix make the price 20 bucks lower with price match all of Ncix prices are higher do they price match and beat the price??? or just match it cause if they just match it wouldnt make the price lower.
Old April 28, 2008, 02:46 PM
Dashock's Avatar
come to think of it after my order in dec of 2 8800GT's and 1 fan im kinda scared about ordering from DC i took almost a month to get my stuff and worst part is i got the fan in one package a week earlier and the video cards inanother package a week after boy was i pissed back then but they said it was cause of holiday buying and blablbla just lack of communication. Anyways ill try to price match but i must say the 2 orders i did with them before the last one was perfect i dont know what happened!
  #19 (permalink)
Old April 28, 2008, 03:19 PM
Jack Rabbit's Avatar
Since the tubing is slightly smaller than the barbs (1/2" barb, 7/16") will Dashock have to do the "soak in hot water" thing or can he just jam them together?
- James Graham
  #20 (permalink)
Old April 28, 2008, 03:33 PM
MpG's Avatar
MpG MpG is offline
Hose clamps? Zip ties? Or hose clamps from your local plumbing/auto store? Regardless, make sure you have something to keep the tubing on the barbs.
