Old July 26, 2013, 12:53 PM
sswilson's Avatar
Default CPU block in parallel with GPU block?
Has anybody here tried this?
I'm new(ish) to GPU cooling so it never crossed my mind to even consider it.
I know that SLI'd cards are run in parallel to each other and that the flow sorts itself out, but I'm wondering if the same could be said for putting the CPU block in parallel with a single GPU. What I'm considering is Pump - Rad - GPU (Front Left) - out from GPU (Front Right) - CPU - GPU Rear Right - out from GPU Rear Left - Res/Pump.
It would certainly make the loop a lot cleaner.
Old July 26, 2013, 12:59 PM
dustin1706's Avatar
The issue is that your CPU and GPU blocks will likely have a different amount of restriction and the fluid will of course take the path of least resistance. If, by chance, they are equally restrictive it could work, but odds are one would receive the majority of the flow.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old July 26, 2013, 01:02 PM
sswilson's Avatar
That's my initial thoughts but I'm wondering how much of a difference it would make. Probably too much of a difference, but it certainly would make for an sweet looking loop. :)
Old July 26, 2013, 01:21 PM
Each loop is different. I say spend the $20 on tubing for a test loop and record the results ;)
heatware
Old July 26, 2013, 01:38 PM
sswilson's Avatar
Heh... I may actually take a fit and try that. I've got enough old lengths of 1/2" tubing kicking around that I could probably make up a couple of loose loops without having to buy new tubing (I've got another 10' of the black primochill ordered anywise). Now it's just a matter of coming up with a few extra barbs that won't leak all over the bloody place. :)
Old July 26, 2013, 03:17 PM
KaptCrunch's Avatar
keep same length to GPU's from Y
Old July 26, 2013, 04:22 PM
sswilson's Avatar
Wouldn't solve my issue.
Name:  Parallel GPU-CPU loop.jpg
This is basically what I'm suggesting as opposed to having a long run which loops over the GFX card to get to the cpu and then back through the GPU in series.
There are several different things I could do (such as switching that current rad input line to the bottom so that the top one is an easier reach for the cpu) but if this would work it would result in a fairly tight loop considering the distance I have to travel from the bottom section pump/res.
Old July 26, 2013, 04:29 PM
lowfat's Avatar
How restrictive is your CPU block? If it is a very restrictive block you could run in to problems w/ your CPU temperature. But if it happens to have a pressure drop similar to your GPU block you should be ok. Flow across each block will be significantly lower though.
I have done GPU + GPU + CPU parallel in the past and it was ok. I didn't try series to see how it compared for CPU temps though.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 26, 2013, 04:38 PM
sswilson's Avatar
It doesn't look restrictive at all... basically a large copper ridged heatsink with wide channels and big thick ribs. I know it's not scientific, but blowing air through it doesn't seem to indicate much restriction. I'm inclined to give it a shot, if it doesn't keep temps down then I'll have to redo the loop.
Old July 26, 2013, 04:48 PM
If that's the cpu block I sold you its not very restrictive at all man. Give it a go man and let us know how it goes!
Mah Rig now
Mah Rig before
My stuff for sale.
Vid block nasrott Water Cooling 1 April 27, 2012 05:04 AM
The value of a GTX 480 with EK WC block Lanboy Off Topic 0 May 29, 2011 05:09 PM
Want to add a block to my gtx 480 botat29 Water Cooling 8 October 16, 2010 04:54 PM
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 12:53 PM
