  #31 (permalink)
Old July 30, 2013, 06:18 PM
Originally Posted by sswilson View Post
This isn't so much about order as it is with flow patterns. IMO order doesn't have much effect at all (maybe 1 - 2c max) but a parallel loop without matching restrictions could have a drastic effect if the majority of water flow ends up favoring one leg of the cct vrs another (path of least resistance). I wish I knew more about flow dynamics in a closed loop though, because I'm wondering if perhaps fast flow past the output of the slower loop portion doesn't create a vortex that acts as a vacuum to get flow through that "slower" portion.
Does that make any sense at all?
that vacuum you are describing is called the venturi effect. We used to use venturi TEEs to create the exact effect you are describing to pull hot water through a radiator. To transfer heat to a room.
Venturi effect - Wikipedia, the free encyclopedia
Mah Rig now
Mah Rig before
My stuff for sale.
  #32 (permalink)
Old July 30, 2013, 06:33 PM
sswilson's Avatar
Heh... I was going to say venture, but didn't want to sound like a complete idiot if I was way out in left field. :)
Vid block nasrott Water Cooling 1 April 27, 2012 05:04 AM
The value of a GTX 480 with EK WC block Lanboy Off Topic 0 May 29, 2011 05:09 PM
Want to add a block to my gtx 480 botat29 Water Cooling 8 October 16, 2010 04:54 PM
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 12:53 PM
