Old July 20, 2013, 05:08 AM
mattlef's Avatar
Default Tap Phobia with 6-32 or just buy M3 Screws?
Hey guys,
What would be easier?
Tap my new Phobya 480 with 6-32, or just go out and buy some m3 30mm screws?
CC-HotSpot Host
YouTube Instagram Twitter
Old July 20, 2013, 05:46 AM
KaptCrunch's Avatar
i would hand tap 6-32 rad hole on a drillpress with power cord out and use template to drill case
and get some nuts and threaded 6-32 rods long enough for fans, case, grill
spin on nut, cut lenght needed then move nut to edge an file rod flat
with longnose pliars, hold nut an screw in rod first through rad tang then nut making a stud
do rest then slip on fans
Old July 20, 2013, 06:01 AM
mattlef's Avatar
Sounds like a great option. However all I have is a cordless drill and a dremel
CC-HotSpot Host
Old July 20, 2013, 06:25 AM
KaptCrunch's Avatar
half way there dremel
if super around can use drillpress let me know and will get it
Old July 20, 2013, 06:29 AM
mattlef's Avatar
I think I might just head over to home hardware and get some M3-30mm screws. there is one about 2km from me. So it might be the best option for me now. :)
I don't want to risk ruining the threads
CC-HotSpot Host
Old July 20, 2013, 06:53 AM
KaptCrunch's Avatar
its plain sheet metal you screw into Rad header
Do Not have screw touch rad tubes, calculate length first
Old July 20, 2013, 06:54 AM
IRQ Conflict's Avatar
Take the rad to a machine shop. You can get them to do it for cheap.
Old July 20, 2013, 07:01 AM
lowfat's Avatar
Better yet tap to M4. The threads are going to be more resilient. When you tap the hole but a piece of scrap metal under the thread to prevent drilling in to the actual radiator.
Mael
Big Lian Li
Forever Alone
Old July 20, 2013, 07:22 AM
KaptCrunch's Avatar
1000% safe scrap sheet metal under the hole while drill/tap or use a coin
Old July 20, 2013, 07:36 AM
mattlef's Avatar
The rad has a plate protecting the core. so i wont be able to over screw or over-tap.
I think my best bet would be just to get the screws to be honest guys. Its the most painless way to do it. I can find the ones i need at any home hardware: Home Hardware - 5 Pack M3 x 30mm Zinc Plated Pan Head Machine Screws
I can paint them black if need be :)
I live uptown Toronto, so there wont be many machine shops around. Unless someone knows of a place by yonge and sheppard, or lives near me who can tap it for me....
Maybe I'll just buy a tap and do it by hand here at home.
CC-HotSpot Host
m4 screws Pabz0r545 Water Cooling 17 May 1, 2012 01:31 PM
H60 fan screws jtktam Water Cooling 11 February 19, 2012 06:54 PM
Rad screws? Birk Water Cooling 13 January 8, 2012 10:07 PM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
