-   -   Ekwb acetal 6990 block (http://www.hardwarecanucks.com/forum/water-cooling/61822-ekwb-acetal-6990-block.html)
r0k0 June 23, 2013 02:45 PM
I've had to open up the gpu block because it was leaking and also its used and bought from bigfoid
So anyways is there a special way to helo those damn rubber o ring ( big huge one ) into place ?
IRQ Conflict June 23, 2013 03:19 PM
helo=hold?
Usually O-rings are held in place by pressure being exerted on it. If yours is leaking you may need a new one.
lowfat June 23, 2013 05:04 PM
Try using a bit of silicon grease or Vaseline.
r0k0 June 23, 2013 05:08 PM
Thanks lowfat !! Vaselin it is
