Old June 1, 2013, 05:59 PM
Default EVGA GTX 780 hydro copper
I'm thinking about buying one of those. It seems like a fairly good deal to me, 800$ with the full water block already mounted and ready to use...
Do you guys think it'll perform worse than if I buy a block from an established watercooling company? Has anyone tried EVGA blocks before?
Old June 1, 2013, 08:08 PM
lowfat's Avatar
Hydrocopper blocks are made by Swiftech. Most VGA blocks perform very similar anyways.
Mael
Big Lian Li
Forever Alone
Old June 1, 2013, 09:09 PM
dustin1706's Avatar
I've had Swiftech, EK and EVGA. They all performed about the same, it's just down to looks. I had a hydro copper 580 and currently have a 680. It is cheaper to buy than an air card and aftermarket block, but can be more difficult to resell as you are limited to watercoolers.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old June 1, 2013, 09:21 PM
Let's splurge then! Ordered from newegg. Still waiting for the haswell cpu and motherboards, then I'll have a brand new system to build. I haven't upgraded in 3 years, so now I'm excited!
Old June 1, 2013, 10:14 PM
crazyea's Avatar
ncix has haswell cpu's and mobo's up as of now.
Please check my feedback:
RFD
HWC
Heatware
Old June 2, 2013, 03:05 AM
Looks like a sweet package. Are those evga branded lok-seal fittings?
Old June 2, 2013, 12:29 PM
Probably, it's just swiftech parts though no matter what sticker or screening is put on them.
Old June 2, 2013, 06:14 PM
I f-ed up a 285 adding a Full block a few years ago by over tightening the screws.
I have since learned from my mistake.'
With that said, Cards that come with Blocks on them cost more then they should, BUT give you a No hassle working card.
If your putting you block on your self, Do do like me, ITS NOT a Big block V8, And does not need 80 LBS or torque
Old June 2, 2013, 08:56 PM
Yeah I was super careful putting on the block on my (then $450) 5870 card. It went well, but if I can save me the hassle, I'm all for it. I only paid 780$ for the card, since I used the $30 off newegg promo. That's only $120 for the installed waterblock, and you also save on shipping since you don't need to order a waterblock separately.
Pretty good deal so far, as long as it works as advertised. I'll let you guys know when I get it.
Two EVGA GTX 580's Hydro Copper 2's 3GB deinosaur Price Check 5 December 24, 2012 10:06 PM
EVGA 480 FTW Hydro Copper (water block ) in stock ZZLEE Video Cards 0 May 23, 2010 05:01 PM
EVGA GTX 295 co-op hydro copper Realityshift Water Cooling 7 April 4, 2010 08:31 PM
EVGA Geforce GTX285 Hydro Copper CasheKicker Water Cooling 4 February 28, 2009 12:43 PM
