Old May 31, 2013, 08:12 PM
robotninjasrule's Avatar
Default coolermaster HAF xb build!
Anyways long time lurker, finally decided to post!
So I decided to do a full water loop instead of the silly all in ones. Some reason I fell in love With this case. I wanted to mount the rads inside but that was not gonna happen Lol!
Stupid noctua fans are so ugly but at 12 bux a pop I figured I could over look it
Dam posting pics on my phone sucks!
Now just need to wait for my daz order and haswell!
Old June 1, 2013, 01:16 AM
Bungwirez's Avatar
interesting modifications. welcome to HWC.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old June 1, 2013, 06:59 AM
Keltron 3030's Avatar
I'm curious about the top panel fan config. Can it fit 4 120mm fans up top?
I'm curious to see if a Phobya 480 could fit up there internally...
FFFFFFFUUUUUUUUUUUU-
Old June 1, 2013, 09:10 AM
Hail Ceasar's Avatar
Can't wait to see more, I want an XB for my next build!
Intel i7 Quad Core 920 @3.8GHz | eVGA X58 x3 SLI | HAF 932 | Corsair 1000w | WD SSD 256gb | WD 3200 1TB | Seagate 2TB | 6x2GB DDR3 Mushkin XP3| MSI GTX 680+EK WB| 24" BENQ E2400HD | 19" Samsung 953BW
Swiftech 655 | Swiftech MCR220 | Apogee GTZ+1366 | EK Spinbay Res | EK Waterblock | Primochill 5/8" | Bitspower Compression Fittings
Old June 1, 2013, 04:04 PM
Thanks for the welcome! I don't think it can fit 4 120s nice, would over hang.
Old June 1, 2013, 04:16 PM
So it was a nice day and I decided to mount my resume/pump. I wanted too mount it on the inside on the bottom but I previously mounted a 3.5 inch HD rack instead of the stock 2.5. Would have got a bigger red if I would have know.
Wonder if the D5 pumps heat up I could use those 80mm fan spots.
Also decided to drill the holes for the gromets i stole from my old fractal case.
Pls excuse the terrible camera phone photos, no computer to upload good ones.
Old June 5, 2013, 03:28 PM
So I decided to mount my 7950's water block too bad I had got a dcuii v2 as a return RMA. Ek does not make a full cover for it! I ended up buying bunch of ram sinks from dazmode and a swiftech mc21 for the vrms. But....
With a little grinding I was able to make the water block fit over the stock v2 vrm cooler. With some old stand offs I had laying around I also mounted a 80mm fan, hopefully that keeps the vrm in check.
Just need those dam asus ROG boards to get in stock!
Old June 5, 2013, 06:36 PM
lowfat's Avatar
VRMs don't need a whole lot of cooling. What you have pictured will definitely be sufficient. Hell I ran a Titan w/o sinks no problem. All I had was a fan pointed over top of them.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 7, 2013, 08:46 AM
I think so too. Just going back to my 5870 days where the vrms would constantly reach 110+ stock lol
Old June 7, 2013, 04:32 PM
Decided to route a couple hoses, I really need the motherboard to come in so I can bolt this stuff down!
Freaking non reference cards, I am seriously considering just buying 2x 780s lol
Should have gone with a 5/8 O/D I think to make it a bit easier to route
mITX build Coolermaster Elite 120 vagnaar Case Mods, Worklog & Gallery 12 February 11, 2013 12:51 PM
Coolermaster 690 II build w/pics NineLives New Builds 1 September 26, 2011 04:35 PM
coolermaster v8 in a coolermaster 330!!! Remoth Case Mods, Worklog & Gallery 10 November 12, 2009 03:04 PM
Coolermaster OEM ? Soultribunal Power Supplies 3 October 8, 2009 04:15 PM
Coolermaster Cosmos S Non-XSPC review on a Watercooling build Dashock Member Reviews 72 October 25, 2008 06:33 AM
