Old May 30, 2013, 08:54 AM
Default paint stripper for rads
I currently have two black ice rads and just curious if there is a solution that will not damage them but stripe the black paint off them. Any ideas guys/girls.
Old May 30, 2013, 09:06 AM
mataribot's Avatar
I used a rotary tool and a mouse sander on my last GTX. It took several hours more than I wanted it to, but I had a difficult time getting it off. Not sure if there is a stripper that will remove that paint job completely without some damage.
Old May 30, 2013, 09:41 AM
wirerogue's Avatar
lacquer thinner should work.
the rads may be powder coated, which means the paint is baked on and more difficult to remove.
you may still need to assist the lacquer thinner with some steel wool or some other abrasive.
paint thinner will not remove paint that has already dried, only lacquer thinner will do this.
rads... how much of 'em? MG2R Water Cooling 9 December 8, 2012 07:55 AM
Best Paint to use to paint a RAD and components? Soullessone21 Water Cooling 5 February 22, 2012 06:03 PM
D5 w/ EK top + 3 x 360 rads Prolab Water Cooling 6 October 21, 2011 07:14 PM
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
