Old May 24, 2013, 04:59 PM
hero1's Avatar
Post Help me pick best parts for rig
Hey everyone. How is it going? So I have been waiting for the GTX 780 to come out and here it is. Now I had ordered watercooling parts for the CPU and I cancelled. I originally wanted to watercool everything and I will do so, however, my case the FDD XL R2 can't fit full height radiators for either 240 or 280. So my choice is to wait for the NZXT H630 and sell my current rig.
Here's how I want the loop to be:
Res-->Pump-->CPU-->Chipset-->280mm rad---> GPU1-->GPU2-->360mm rad-->Res
My rig: ASUS Max V Form, Core i5 3570K, eVGA GTX 780 (SLI in a week but won't out the second card until I have the watercooling stuff), 16 GB Ram, 256GB SSD (getting another since I gave one to my wife) etc..
Inputs are welcome
Old May 24, 2013, 05:08 PM
hero1's Avatar
And here's what I have in mind with respect to parts. And I know I will have to wait for the GTX 780 water block to come out.
EK-CoolStream RAD XTX (360)
EK-Supremacy Elite - Intel 115x - CPU Blocks - Blocks
Old May 24, 2013, 06:05 PM
lowfat's Avatar
Titan blocks and backplates are compatible w/ GTX 780.
Loop order is also completely meaningless. Because our loops are so small water temperature reaches an equilibrium throughout the entire loop.
Block choices and radiator choices also account for very little when it comes to performance. All blocks perform within a couple of degrees of each other. Same goes w/ radiators. Just make sure you go w/ a low FPI radiator if you are going to silence. Also if you are going w/ 140mm radiators make sure the fan spacing of your case matches the fan spacing of the radiator. Most cases use 20mm spacing between the 140mm fan mounts BUT most radiator manufacturers use 16mm spacing. HWLabs is the only one I know of that still uses 20mm spacing on the radiators. They are unfortunately expensive but without a doubt the leader when it comes to build quality and aesthetics.
That is a fantastic looking block IMO.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 24, 2013, 08:22 PM
hero1's Avatar
Yeah I like the waterblock and it's the one I am going for. I want a full sized rad so long that it has low fpi for sure. I will do 120mm fans for 360mm rad and 140mm for 280mm rad. I will make sure to look for ones that have 15-16mm spacing. My current case has 15mm spacing for 140 mm fans.
Old May 25, 2013, 05:18 AM
Alphacool rad look really sexy and Fpi is low. I am not 100% but I believe the spacing for a mounting them is 16mm. You can also get them from 45mm to 80mm thick in 140mm wide.
Old May 25, 2013, 12:47 PM
hero1's Avatar
I will definitely have to look for a better case or mod this one. I have taken a look at the NZXT H630 and I like it. The other option would be to air cool the cards and custom water cool the CPU. I like Alphacool stuff, they have 15mm spacing and EKWB have 16mm spacing for mounting. I am most likely to buy everything from EKWB. Now I just need a case.
What do you guys think about this kit: EK-KIT H3O 240 HFX - Kits - Starter Kits & Chassis
Things that I have picked:
Rads:
EK-CoolStream RAD XTX (240)
Blocks:
CPU: EK-Supremacy Elite - Intel 115x - CPU Blocks - Blocks
GPU: EK-FC Titan XXL Edition incl. Backplate - GeForce GTX 7x0/Titan Series - Full Cover for Nvidia GeForce - VGA Blocks - Blocks
Res and Pump
EK-RES X3 250 - Reservoirs - Reservoirs & Accessories
Laing D5 Vario 12V DC Pump (MCP 655) - Pumps - Pumps & Accessories
Old May 26, 2013, 05:08 PM
hero1's Avatar
Here's the kit I am looking at for CPU cooling as I contemplate watercooling the cards and whether or not to have 2 of them. Let me know what you guys think and I can mount this on the front of the case.
Old May 26, 2013, 05:22 PM
lowfat's Avatar
Where do you plan on buying your equipment? Buying from the EKWB store is generally expensive.
Queen of Dreams WIP
Big Lian Li
Complete
Old May 26, 2013, 05:26 PM
hero1's Avatar
Smile
I intend to buy it from Dazmode. But I might buy the rest of the stuff from EKWB since I have an account with them and they have offered me 10% off at the checkout. So what's your take on the kit? I don't like the CPU block so I might just put something together on Daz with the CPU block that I have picked, shown above.
Old May 26, 2013, 05:44 PM
lowfat's Avatar
You will be paying brokerage fees if you buy from the EKWB store as they use DHL. I had to pay $40 at my door for two GTX680 blocks last year.
I sent a message to Daz earlier to see when he'll be getting the XXL Titan blocks back in stock. Buy buying those blocks @ his store I'd save like $70 on two blocks.
As for the kit, it isn't bad but I don't like the pump much. I like to stick w/ Laing when it comes to pumps. I've been using them for nearly 10 years and have never had any issues with them.
The block included will perform identically to the Elite above, it just doesn't look as nice.
Queen of Dreams WIP
Big Lian Li
Complete
[FS] Silverstone GD05B Chalaska Buy/Sell & Trade 37 April 7, 2014 10:10 PM
[FS] Few old computer parts - mobo, few ram sticks and few parts GreenPC Buy/Sell & Trade 9 April 5, 2012 05:48 PM
New build (Help pick out some parts) Mr. Toda New Builds 14 January 19, 2011 01:04 PM
Help me pick my parts! BrokenHalo83 Water Cooling 21 May 10, 2009 06:31 PM
Help me pick parts! encorp Water Cooling 12 September 15, 2008 10:56 PM
