  #31 (permalink)
Old May 29, 2013, 07:16 AM
hero1's Avatar
I just received the items: Wohooo!
  #32 (permalink)
Old May 29, 2013, 08:06 AM
lowfat's Avatar
Did you have to pay any brokerage?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #33 (permalink)
Old May 29, 2013, 11:01 AM
hero1's Avatar
Smile
Nope. I bought it from Dazmode. Just having issues with mounting the pump. They have a chart showing that I can mount the res and pump together but it won't work for me. So now I have to decide where the pump goes. I also descovered that I could fit the rad with fans mounted at the top if the fittings other comes with the motherboard were 90 degrees angles ones instead of barbs. Damn!
Wrong instructions for this package when it comes to mounting the pump with the reservoir. They need to include the EK-DCP 4.0 combo reservoir and not the one they sell to people with the package.
  #34 (permalink)
Old May 29, 2013, 03:54 PM
hero1's Avatar
Do I have to do a full 24 hr test or is an hr enough? So far I have no leaks from any connections. The only leaks I got were from the rad due to their cheap plastic plugs. So I used the plugs that came from the reservoir and no more leaks. Can I just go ahead and power it up now or keep running it on the external PSU for 24 hrs?
  #35 (permalink)
Old May 29, 2013, 03:58 PM
lowfat's Avatar
If my loop doesn't leak by the time I am done bleeding that is good enough for me. Just double and triple check that your fittings are tight and there is no leak between the fittings and the block. Most of the time that is where something will leak.
Queen of Dreams WIP
Big Lian Li
Complete
  #36 (permalink)
Old May 29, 2013, 04:11 PM
hero1's Avatar
Smile
Ok. I checked everything again and they're all good. Fittings are tight as heck and the pump is running smooth. Time to fire this baby up for real.
  #37 (permalink)
Old May 29, 2013, 05:23 PM
hero1's Avatar
All is well and running smooth. I just want that damn NZXT H630 here asap so I can do what I want, add another rad. Should I use anything other than purified water?
  #38 (permalink)
Old May 29, 2013, 05:53 PM
distilled water is enough for most loops. I add a couple OZ of glycol to my loops but that's optional.
Don't over tighten fittings on your blocks and stuff. Especially if they are plastic holes... easy to crack or strip threads. Hand tight with a little tweak is enough.
Mah Rig now
Mah Rig before
My stuff for sale.
  #39 (permalink)
Old May 29, 2013, 06:53 PM
hero1's Avatar
Smile
I had them tightened the. Loosened them a bit afterwards. Thanks for the tips.
  #40 (permalink)
Old May 29, 2013, 07:51 PM
lowfat's Avatar
Definitely only hand tighten them.
Queen of Dreams WIP
Big Lian Li
Complete
[FS] Silverstone GD05B Chalaska Buy/Sell & Trade 37 April 7, 2014 10:10 PM
[FS] Few old computer parts - mobo, few ram sticks and few parts GreenPC Buy/Sell & Trade 9 April 5, 2012 05:48 PM
New build (Help pick out some parts) Mr. Toda New Builds 14 January 19, 2011 01:04 PM
Help me pick my parts! BrokenHalo83 Water Cooling 21 May 10, 2009 06:31 PM
Help me pick parts! encorp Water Cooling 12 September 15, 2008 10:56 PM
