  #21 (permalink)
Old May 27, 2013, 03:27 PM
hero1's Avatar
Originally Posted by lowfat View Post
Not sure what you mean by this.
killcoil is a wire made of 99.9991% silver (UBER PURE KILLCOIL 99.9991% Silver Wire 0.25mm - 250mm) that you put in the reservoir to prevent algae build up. And jumping the PSU: Power supply blew up (Smoking with Fire!) this is done to make the PSU run without having the 24Pin ATX connector plugged into the board. It's done during testing phase to check for leaks and make sure everything runs accordingly.
Am I missing something?
  #22 (permalink)
Old May 27, 2013, 04:26 PM
lowfat's Avatar
I bolded the part of the post that I didn't understand what you meant by it. I know what a kill coil is.
You said
can I just unplug the 24-Pin ATX power cable?
which is what I didn't know what you meant by it.
If you have an old PSU laying around I find bleeding a lot w/ a seperate PSU is a lot easier. That way you don't need to disconnect all the cables from everything in your computer. Just plug the pump in to the spare psu, then jump it.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #23 (permalink)
Old May 27, 2013, 05:51 PM
hero1's Avatar
The 24-pin ATX motherboard cable: I was wondering whether I can just unplug it from the PSU or jump it? I'll just jump it since I don't have a spare PSU.
  #24 (permalink)
Old May 27, 2013, 06:05 PM
Jump it... green wire to any black wire... easiest is the black wire 2 over from the green wire. Done deal. Just make sure it's not gonna pop out of there and short out on anything (it's almost happened to me)
Kill coil is pointless unless you leave your rig off for weeks at a time. Algae isn't going to grow in moving liquid and a tiny bit of glycol in your loop will prevent anything from growing which is exactly what that Dazmode stuff is.
Mah Rig now
Mah Rig before
My stuff for sale.
  #25 (permalink)
Old May 27, 2013, 07:29 PM
hero1's Avatar
The hardest thing is that I can't tell which is green and which is black with respect to the Corsair AX850 PSU. It's all black!
  #26 (permalink)
Old May 27, 2013, 08:02 PM
Bleeding 24-pin ATX jump start connector for power supply
Grab one of these the next time you order water cooling stuff. Problem solved.
Kaptcrunch posted a picture didn't he? If someone counts the wires for you from the clip side it will be the same. I am working outta town until Friday so if someone hasn't posted by then I will.
http://marcomiltenburg.com/wp-conten...-Connector.jpg
Mah Rig now
Mah Rig before
My stuff for sale.
  #27 (permalink)
Old May 27, 2013, 08:30 PM
hero1's Avatar
Thanks bud but that item is sold out. I found a forum on OCN that shows how to jump the AX850 PSU. Looks like I am all set. Also, can I forgo the mixture that comes with the kit and just use DW?
  #28 (permalink)
Old May 28, 2013, 02:24 PM
hero1's Avatar
The package is on the way and I decided to buy s cheap PSU to do the test instead of having to unplug and jump my current setup. Woohoo!
  #29 (permalink)
Old May 28, 2013, 04:02 PM
Yeh DW is fine as long as you keep your rig running more often than not. Flush all your components with DW as well as it's never a bad idea. DW is cheap as all hell too so it's of little consequence if you waste some down the drain. I've decided to use the dongle I bought from Daz to keep my loop pumping when I'm away but I wont have to keep the mobo/vid powered up.
Grats on the cheapo PSU its the easiest way.
Mah Rig now
Mah Rig before
My stuff for sale.
  #30 (permalink)
Old May 28, 2013, 04:07 PM
hero1's Avatar
Thanks for advice man. What else am I missing here? Do I need a T-line adapter for draining the loop when I want to expand it? I will also try and see if I can grab a sleeved cable kit to help easy the mounting of a 45mm thick radiator at the top. Why? Because I think I can cool 2 cards and a CPU using 2x240mm radiators. Am I wrong to think this way?
P.S: I just realised that I can take out the PSU from Wife's PC and use that to run the test tomorrow. But, I still will buy a small PSU just for future work. Muahahahaha!
[FS] Silverstone GD05B Chalaska Buy/Sell & Trade 37 April 7, 2014 10:10 PM
[FS] Few old computer parts - mobo, few ram sticks and few parts GreenPC Buy/Sell & Trade 9 April 5, 2012 05:48 PM
New build (Help pick out some parts) Mr. Toda New Builds 14 January 19, 2011 01:04 PM
Help me pick my parts! BrokenHalo83 Water Cooling 21 May 10, 2009 06:31 PM
Help me pick parts! encorp Water Cooling 12 September 15, 2008 10:56 PM
