Old May 10, 2013, 11:06 PM
mataribot's Avatar
If you setup dual loops + correctly, you may have a slightly easier time cleaning your loop. Also, less rad on your GPU only loop. However, I'm not sure it's worth the cost and effort.
Old May 11, 2013, 07:44 AM
WhippWhapp's Avatar
A single loop where your rads share load is more efficient, I've tried both.
In my experience, 5/8" tubing is easier to work with, less prone to kinks- the difference in flow rate affecting temperature is negligible.
I rub and whack and choke and stroke!
Old May 11, 2013, 08:21 PM
mataribot's Avatar
Not about efficiency- it's about shaving a couple degrees on your cpu provided you don't have enough rad. GPUs are designed to run hot, so who cares if do.
Old May 12, 2013, 06:49 AM
Warcrimes's Avatar
I guess ill add another rad in a single loop would save me alteast a couple bucks thanks for the input i really appreciate it .
Old May 13, 2013, 07:31 AM
a lot of guys will run water through one rad to cool the cpu and mobo (sometimes ram). Then they will run through another rad before hitting the vid card(s). If you are really wanting to push the limits you could also consider using a water cooling unit exactly like they use to maintain temps in high end fish tanks.
Aquarium Chillers & Fish Tank Chillers
I've seen a couple builds out there using these things but you really gotta understand dew point to prevent the blocks from sweating/condensation. Dew points change constantly... if you've ever seen a toilet sweat or have water around the tank. Same thing.
Mah Rig now
Mah Rig before
My stuff for sale.
Old May 15, 2013, 10:07 AM
Warcrimes's Avatar
its probably a little more than im doing im going to push my cpu the most, atleast 5.2 Ghz either 1155 or 2011 cpu type dunno yet 3X(xfire), Ill OC GPU's as well. mobo and eventually ram i dont understand OC'ing ram yet im still learning hence y im waiting
Old May 15, 2013, 10:48 PM
not to sure if OCing the ram is what a highly OC'd cpu can deal with. Simply having highly overclockable ram (high frequency) gives someone the head room to OC the cpu more. If anything people tend to drop the ram settings to stabilize a high OC... I have; in the past, water cooled ram and it was beneficial to stabilizing the cpu and squeezing a little more outta the cpu. While water cooling the ram has been debated over the years I had to try for myself and see and discovered it did help more than not.
Are you planning to maintain a heavy OC or is it just for testing/fun. Do you maintain a lower OC regularly?
Mah Rig now
Mah Rig before
My stuff for sale.
Old May 16, 2013, 01:32 AM
Warcrimes's Avatar
Well ive OC my processor several times and the best settings i have found is @ 4.5Ghz and 4.8Ghz. MY goal is to break the 5Ghz mark and keep stable for benchmarking, gaming etc
  #19 (permalink)
Old May 16, 2013, 02:05 PM
nasrott's Avatar
I use a couple rads myself in one loop.
Primochill Tubing or any good tubing with thick walls in Vancouver Lower Mainland? bjornbjorn Water Cooling 5 January 26, 2012 05:19 PM
Fitting/pump Help homer98 Water Cooling 20 December 2, 2010 09:23 PM
Need some barb/fitting advice (W/C noob) Aix Water Cooling 8 July 29, 2010 10:23 PM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
advice for updating tubing and pump. TAOTAO161 Water Cooling 15 February 5, 2009 11:31 PM
