Old May 8, 2013, 10:38 PM
Default Worth it on my setup?
I just bought an x79 with 3930k and GTX 690. The seller also included a pump and radiator that has not been setup yet. I don't have waterblocks or any tubing yet. Would it be worthwhile for me to buy the parts and complete the setup or should I just sell the watercooling stuff and stay on air?
Old May 8, 2013, 10:54 PM
lowfat's Avatar
If you plan on overclocking the 3930k I would say yes. They do throw a lot of heat. By moving from a Noctua NH-D14 to water I gained 200MHz and dropped 10C. As for the GTX690 it depends on if you plan on overclocking and your noise tolerance. It does have a rather decent HSF, if you aren't overclocking I doubt it should get all that loud w/ the default fan profile.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
How much is this worth? kruzn4evr Off Topic 18 May 12, 2010 07:24 PM
How much is my stuff worth Core Unlocked Phenom 2 X2 Setup? kingnubian Off Topic 2 April 5, 2010 03:51 AM
How much is my PC worth? ezytgr Off Topic 6 March 29, 2010 07:09 PM
Could someone tell me what this is worth? BootlegUsher Off Topic 14 December 19, 2009 02:14 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
