  #21 (permalink)
Old June 3, 2013, 06:50 PM
rjbarker's Avatar
I'm only running 2 Noctua fans but push not pull (don't think pulling air through the Rad would be all that effective IMO), yes your temps are high for no OC.
Fans plugged into pump header and controlled with Links software.
My temps Max out running LinX @4.7 Ghz 75c.
Ensure your pump is tightened down nice n firm, set Links Fans speed to performance and see if that helps.
Firestrike Extreme: 21.452
MARK 11: 32.530
  #22 (permalink)
Old June 4, 2013, 02:33 AM
nasrott's Avatar
Used my push pull on the 100 connected to my fan controller not the corsair controller.
  #23 (permalink)
Old June 4, 2013, 04:08 PM
what's your max noctua f12 fan speed? (from noctua site it suggest 1500rpm (+-10%) , but i also heard ppl pushing around 2000rpm)
from corsair link2 the max i can get from fan 1 is 1332 and 1373 for fan 2.
  #24 (permalink)
Old June 5, 2013, 01:05 PM
rjbarker's Avatar
These re the fans
Noctua NF-F12 PWM 120MM Ultra Quiet Cooling Fan 300-1500RPM 93.1M3/H 22.4DBA 4-PIN PWM
Rated 300 - 1500 RPM....through Corsair Link Software shows 1360 or thereabouts for me as well in Performance Mode....seems fine. If you want highr RPM (right to 1500) try going straight to PS or Mobo Header.
MARK 11: 32.530
Silverstone TJ09 & H100i rjbarker Cases 0 March 26, 2013 07:14 PM
No bios no nothing after H100i install Jeff1961 Water Cooling 23 March 3, 2013 06:28 AM
push pull config overclockdrew Air Cooling 5 June 1, 2011 01:36 AM
Push/Pull config - Hyper 212+ Owners JMCD Air Cooling 3 October 11, 2009 09:01 PM
Push-Pull CPU HSF Config Question CORE Air Cooling 3 July 2, 2009 04:53 AM
