Old April 28, 2013, 04:03 PM
nasrott's Avatar
Your jumping into x79 before haswell is released.
Old April 28, 2013, 04:51 PM
rjbarker's Avatar
Yep, if I'm going from 6 Core 12 Thread 980x X58 platform anything other than X79 2011 Socket would be a step backwards ;) ........even Haswell !!!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old April 28, 2013, 08:09 PM
concinnity's Avatar
No problem running pull only. And you can vacuum the dust out of the rad that way.
Getting information off the Internet is like taking a drink from a fire hydrant.
Old April 29, 2013, 03:10 PM
Caldezar's Avatar
Done! I grabbed 2 NF F12's and put them in 'push' config pulling cold air from the top down in to the case. Pretty slick actually, as you almost can't see them from the inside at all. Unfortunately, they can be seen clearly from the top of the case through the meshing. But they are extremely silent and keeping things cool... so I can't complain much.
Old April 30, 2013, 08:51 AM
rjbarker's Avatar
Surfing other sites the consensus appears to be arranging the fans in that config.
Like yourself I also have a vertical top Fan exhausting out the back, so the warm air isn't going to build up at all in the case.
Also, you provide air blowing onto the Mobo as well.
I find the humming from the pump in Performance mode a little annoying, but only use it when gaming, turn up the volume ;)
MARK 11: 32.530
Old April 30, 2013, 05:47 PM
Is it just a consensus or it is a proven configuration? Generally speaking heat rises and thus it's better to exhaust air out the top. Also the rear "exhaust" fan could be turned to blow across the mobo with cooler air.
While I think it is unlikely that air could easily re-circulate through the case via the rear exhaust (left of the cpu) and back into the top of the case... if the computer was in a cabinet of some kind this could be possible.
heat rises... in my opinion it's better to exhaust heat out of the case rather than blow it in.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 30, 2013, 07:01 PM
rjbarker's Avatar
Well when you install your H100i exhaust out the top then
MARK 11: 32.530
Old May 1, 2013, 04:50 PM
never happen man ;) I do my own water setups.
Mah Rig now
Mah Rig before
My stuff for sale.
  #19 (permalink)
Old May 1, 2013, 06:29 PM
rjbarker's Avatar
Your the man ;)
I'm going to change my fan arrangement tomorrow!!! Thanks for the tip!!
Cheers
MARK 11: 32.530
  #20 (permalink)
Old June 3, 2013, 06:37 PM
Hi,
i am running a 3930k stock 3.2ghz turbo boost to 3.8ghz
running prime 95 for 1hr ended up averaging 72c
room temperature is a consistent 23c
Specs are
H100i, 2x noctua f12 pull, 1x noctua s12b push, Corsair 650D
GTX 580 idle at 64c
Kind of hot... any suggestion?
and are you guys running the fan off of the h100i pump or other fan headers?
Silverstone TJ09 & H100i rjbarker Cases 0 March 26, 2013 07:14 PM
No bios no nothing after H100i install Jeff1961 Water Cooling 23 March 3, 2013 06:28 AM
push pull config overclockdrew Air Cooling 5 June 1, 2011 01:36 AM
Push/Pull config - Hyper 212+ Owners JMCD Air Cooling 3 October 11, 2009 09:01 PM
Push-Pull CPU HSF Config Question CORE Air Cooling 3 July 2, 2009 04:53 AM
