Old April 21, 2013, 05:45 PM
Warcrimes's Avatar
Default should i add another rad
i currently am cooling a gtx 590 classy hydro copper and an i7 2600k @ 4.5 Ghz. my case is CM Haf-X. the order in wich its cooled is rad/ res combo to GPU then CPU then rad back to res/pump. I am using an XSPC 360 mm rad on top with 3 120's pushing and 2 200's pulling. my GPU highest temps under full load is 47C and cpu highest under prime 95 58C. i dont know the size of rad i can fit in the front and i could fit single 140 in the back. could there be any significant difference in temp ie above a 5C difference.
any tips/ advice much appreciated
Old April 21, 2013, 06:00 PM
ZZLEE's Avatar
Try Prime and EVGA OC at the same time and check your temps.
Whats your highest gaming temps.
Looks good if the don't go to much higher.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 21, 2013, 06:56 PM
Warcrimes's Avatar
cpu went max 60C gpu stayed around 36 in OC scanner
Old April 21, 2013, 09:25 PM
ZZLEE's Avatar
Good to go
Old April 21, 2013, 10:34 PM
I like to hit the cpu 1st when cooling but that's personal preference... and only because the cpu TDP is much lower than a video card.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 22, 2013, 11:03 AM
Warcrimes's Avatar
thanks for the tips much appreciated
