Old April 19, 2013, 07:17 PM
One 360 for i7 3820 and a 7970. Maybe a 420mm rad in the future.
Old April 20, 2013, 07:14 AM
KaptCrunch's Avatar
at the moment 130 home made 4 core
Old April 20, 2013, 01:13 PM
Keywork's Avatar
1 x 360 for my i7 920.
Friends don't let friends use onboard video.
Old April 20, 2013, 07:55 PM
JD JD is offline
Originally Posted by G777 View Post
1- 240 & 1-360. Push-pull GT's on both.
"Cause more fans are kool
Similar setup here, though only push-pull GT's on the 240. Just a single set of push GT's on the 360.
Old April 21, 2013, 08:39 AM
Dazmode's Avatar
I will have just single quad in my next build.
Orange Build: Final Video
HTPC Build: Final Video
Old April 21, 2013, 09:00 AM
Mark's Avatar
One think 240 dual rad for the cpu. I like the hsf look on my Titan and have no plans in changing it.
CHEERS
Old April 21, 2013, 09:28 AM
Bao Bao is offline
1x 360mm XSPC AX Series Rad with 5x Gelid 1000 RPM fans (would like to swap in 4x Gentle Typhoons and have them run at 1200).
1x 240mm XSPC RX Series Rad with 4x NZXT LB Fans at 1100 RPM (would put the 4x Gelid's from above into this rad and retire the NZXT fans).
In an NXZT Switch 810 case.
Only cooling an i5-3570K at 4.8ghz and GTX680 at 1200mhz boost. I am looking to upgrading to a 690 or Titan, bit even so, the two rads should be enough!
Old April 21, 2013, 05:36 PM
ZZLEE's Avatar
1X140mm thin push pull and 1x200mm push pull 220 mm fans
3770 4.6 Ghz Folding Hard 95 % tad bit warm right now.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #19 (permalink)
Old April 22, 2013, 02:10 PM
nasrott's Avatar
1 240 , 1- 360 first is for the video, second cpu, one would do both so have the room, also just push on both on lowest sped on controler
  #20 (permalink)
Old April 22, 2013, 04:19 PM
2x 240 for i7 920 + 6970
Heatware
rads... how much of 'em? MG2R Water Cooling 9 December 8, 2012 07:55 AM
mixing rads Raftus Water Cooling 3 December 8, 2012 05:30 AM
D5 w/ EK top + 3 x 360 rads Prolab Water Cooling 6 October 21, 2011 07:14 PM
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
