-   -   need input broken pump? Daz? (http://www.hardwarecanucks.com/forum/water-cooling/60615-need-input-broken-pump-daz.html)
clshades April 9, 2013 03:17 PM
So a friend of mine who's been away from water cooling for quite some time is in the process of building a new setup and this happened:
http://www.hardwarecanucks.com/forum...66-broken.jpeg
Is there an easy fix for this short of replacing the pump? this pump DazMode STORM D5 STRONG 8-24V Pump in the corresponding XSPC resi/pump dual bay unit. I'm outta town working and have been trying to coach him through this a little bit via the internet and phone.
any input on this would be greatly appreciated.
clshades April 9, 2013 03:26 PM
I think this thing just slides over the pump if i'm not mistaken...
SugarJ April 9, 2013 03:39 PM
Yes, that ring just slides over the pump. He might be able to RMA it to Daz/XSPC as that should not happen, it had a crack or manufacturing defect to snap like that.
clshades April 9, 2013 03:49 PM
I have the same units but I couldn't remember if that collar came with the pump or the resi. I'm hoping Daz can help out with this obviously...
KaptCrunch April 9, 2013 04:03 PM
1 Attachment(s)
JUST cut 1/4 alu plate 1 big hole for motor that fits snug and not bigger than 0-ring shoulder and 4 screw holes
clshades April 9, 2013 04:09 PM
I was kinda thinkin the same Kapt... I only know one person with the tools to do that tho.
KaptCrunch April 9, 2013 04:12 PM
its call over torque for mount is flat to pump body http://www.hardwarecanucks.com/forum...66-broken.jpeg
you just need thickness of 0-ring and shoulder thickness GAP between mount to pump body
no more then a full turn of screw once all 3 are in contact (mount/0-ring/body)
or just add washers between body & mount, lets say take 5 washers= shoulder&0-ring .....use 4 washers
Bloodystumps April 9, 2013 04:18 PM
I'm going to have to disagree with you KaptCrunch I would think that is more of a defect then over torquing, had it been over torqued it would have cracked at the screw unless there was something causing the mounting ring to be high in the middle like that..
clshades April 9, 2013 04:21 PM
It's pretty hard to over torque that collar without blowing out the threads in the acrylic I agree.
KaptCrunch April 9, 2013 04:26 PM
1 Attachment(s)
unless mount has a recessed spot on one side of mount
installer used wrong side of mount
