-   -   resevour+pump advice (http://www.hardwarecanucks.com/forum/water-cooling/60577-resevour-pump-advice.html)
Warcrimes April 7, 2013 12:33 AM
Im going to be redoing my loop since its time for a cleaning. Ive noticed a residue buildup at the top of my res and its not in the water but want to clean it out before it does any damage.i am not sure if anyone has used Ice dragon nano fluid. I dont have intentions of using Distilled water with additives and cleaning out ever 4-6 mo.
Ice Dragon Cooling Nanofluid Coolant White Color - 32oz - FrozenCPU.com
im wondering it is going to strain my current pump
XSPC X2O 750 Dual 5.25 Bay Reservoir Pump - Updated Version - FrozenCPU.com
Ive had the pump for a while no problems and im currently using koolance UV red. and thats pretty much like water in terms of viscosity.
Im cooling my i7 2600k @4.5 Ghz and a GTX 590 classified hydro copper
any tips and advice will be appreciated thanks :thumb:
Bungwirez April 7, 2013 05:17 AM
Ice Dragon is a great product. I can't say for sure that it really improves temps, but it looks super.
Your pump will do just fine with it.
Just be sure to do lots of cleaning of your rads and blocks...
IDK about Koolance Red liquids, but I had a little issue with staining.
here's what happened to me after using IDC for about a week.
http://i249.photobucket.com/albums/g...2/P1020694.jpg
http://i249.photobucket.com/albums/g...2/P1020738.jpg
most likely from red TFC tubing used in prior build.
wierd that the IDC is still perfect, just the clear tubes are stained.
still love this stuff, spendy, but cool.
KaptCrunch April 7, 2013 06:13 AM
get your self a syringe http://www.medline.com/media/catalog...0141_HRE01.JPG to suck up the residue of erode
Warcrimes April 7, 2013 10:39 AM
Ok thanks alot for cooling my nerves. the pump i have isnt cream of the crop but has been steady since day 1. ill put the syringe on my list of things to get then.
@Bungwirez. Your rig looks sick, i love how clean it looks. what kind of temps are you running if you dont mind me asking. Playing skyrim on ultra im between 39-44C.
lowfat April 7, 2013 10:57 AM
It is just the tubing that is changing colour correct? That Bitspower block still looks perfectly white to me.
Bungwirez April 7, 2013 12:13 PM
Ya Lowfat. only the tube... the IDC got recycled, looked just like it did the day I bought it...
@Warcrimes... thanks for the comments. my build log here: [Build Log] Bungwirez HAF932
Warcrimes April 7, 2013 01:22 PM
@ Bung wirez your rig is even more sick than i had imagined, sweet log amazing transformation. I have a Haf-X im still a bit of a noob when it comes to mods, ill have to take a page out of your book and learn to hook mine up like that
Bungwirez April 7, 2013 02:30 PM
please do. CMC is a great place to learn.
Warcrimes April 7, 2013 03:38 PM
not sure what CMC is could you please provide a link
canada2005 April 7, 2013 05:39 PM
Case Mod Contest
