Old April 3, 2013, 07:56 PM
I think mine might have just been worn out and I got hosed (buyer beware) Normally you only see compression fittings (of ANY kind) leak when their is pressure on the side of the fitting basically causing the rubber ring to lift off slightly. Which is what lowfat was suggesting. Marks fitting may just be faulty too.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 3, 2013, 08:13 PM
Mark's Avatar
No, I was testing it for my new build. Luckily , since I wouldn't want a leak on my new Titan.
CHEERS
Old April 4, 2013, 03:43 PM
stephengillon's Avatar
Originally Posted by Mark View Post
ek WATERCOOLANT is non conductive
doesnt stay that way for long, soon as it starts touching the rads and blocks it changes, no matter how clean.
plus any dies will make a bad mess.
i soaked a motherboard once, would not work anymore. cleaned it multiple times with 99.9 alcohol and after a few months it started working again. i think it was mostly the dye tho messing with the cpu socket.
Old April 5, 2013, 06:46 AM
Mark's Avatar
Too bad Zerex Supercoolant is no longer available. I had a bottle for 6 years on all the water builds I did and never had a single issue with corrosion or algae growth and all I used was 4 cap fulls on my rigs. Danger Den use to sell 4oz bottles for $3.50.
CHEERS
Old April 5, 2013, 12:22 PM
mataribot's Avatar
In a typical loop, there is no need for anything but distilled and bio.
Old April 5, 2013, 02:49 PM
Mark's Avatar
what type of bio have you used ?
CHEERS
Old April 6, 2013, 09:12 AM
Daz protector, bottle is abit small but good for 1 system or two smaller loops
Old April 11, 2013, 01:56 PM
Mark's Avatar
Just used some Distilled water and a small cap and a half of wetter coolant. That bottle will last me years.
CHEERS
  #19 (permalink)
Old April 14, 2013, 08:15 AM
Dazmode's Avatar
Bad rotary, replace it. It happens quite rarely, but it happens. This why you have to perform leak test (preferably with distilled water to reduce mess).
Orange Build: Final Video
HTPC Build: Final Video
  #20 (permalink)
Old April 20, 2013, 11:14 AM
Mark's Avatar
It's not repairable. Called the company, sent pics and info and they never responded. I can deal with product problems but I cannot deal with companies that do not respond to issues.
Last time I order anything from Bitzpower.
CHEERS
FrozenQ res leak jibz Water Cooling 3 January 10, 2012 07:11 PM
EK multioption Res X2 leak mataribot Water Cooling 15 October 28, 2010 07:58 PM
Gamergrub Contest Leak ziikutv Rumor Mill 1 December 4, 2009 08:32 PM
i got a LEAK! kyle_L Water Cooling 9 May 1, 2009 05:10 AM
Leak in T-line Phobia Water Cooling 17 June 9, 2008 04:37 PM
