-   -   unstable flow because of air? (http://www.hardwarecanucks.com/forum/water-cooling/60467-unstable-flow-because-air.html)
LegendMask March 31, 2013 08:53 AM
OK guys its been 18 hours testing and bleeding my first loop, and bleeding the loop is hella a pain.
I wish I used KaptCrunch's method in bleeding the loop, however I was all by myself, and couldnt do it.
Anyway I noticed something strange and I dont know if its normal or not, while my D5 is set to 1, and I tilt the case a bit to the right side of it, the flow slows down and stops. Is this normal? or is there a problem somewhere in the loop?
Unstable flow? - YouTube
PS: sorry for the noise in the background
IRQ Conflict March 31, 2013 09:08 AM
Just a guess, but I think you may need to top it up. Not enough water in it? Also, why not test it away from your components before assembling it? It would be a shame to get your motherboard wet.
Bloodystumps March 31, 2013 09:11 AM
I'm going to say you found air trapped in the system and when you tilted it it locked up, you could try adjusting the speed on the pump while tilting it to help push the air out..
LegendMask March 31, 2013 09:18 AM
its filled to the top, when I turn it off, the water level goes up touching the fill port cover, if its closed.
the components are not working, plus the leak test went well thank god, around 18 hours and no leak so far.:rofl:
done that, been switching speeds for 6 hours last night, tilted the case upside down multiple times, shook it real hard.
PS: the flow only stops when I have my D5 on speed (1) on other speeds it just slows down but doesnt stop. This might be not a big issue and could be solved by pumping up the speed, but the question here; is it normal for the flow to stop or slow down, when I tilt the case?
Hooded March 31, 2013 09:34 AM
What I did with my XSPC bay res was add a long tube (2') to the res fill port so I was able to keep it open while I rocked the case around a lot to chase the larger air bubbles out. This gives the loop a breather point well above the top rad. Once bled remove the tube.
Your flow is stopping due to an air lock large enough that when your pump is set on 1, it's not pushing hard enough to move the air. Set your pump to 3 for bleeding.
LegendMask March 31, 2013 09:36 AM
will keep the speed up for the next hours, and gonna try to put a tube on the fill port now and tilt the pc a little bit.
thanks guys, will report later tonight :thumb:
LegendMask March 31, 2013 10:16 AM
the air seems to be trapped in the GPU block, I can hear it when I pump the speed all the way up.
after installing a tube on the res fed, and shaking the case real good, I can hear it on the res aswell. I hope it isnt air getting sucked back again. :censored:
ZZLEE March 31, 2013 11:33 AM
Try starts and stops on high settings or let sit fore an hour or two off then starts to high setting.
KaptCrunch March 31, 2013 01:33 PM
lay the tower down (MB flat cpu up)
hard to see if your drain tube on suction side of pump (need more light for camera)
as said before not enough fluid in loop
LegendMask March 31, 2013 01:58 PM
Is it okie to add a little bit of distilled water to feser one clear? Or should I wait till tuesday and place an order for another bottle?
EDIT: NVM I added some distilled water already, now the water is showing on the tube that is connected to the res filler, when I turn it off or tilt it. gonna keep tilting and shutting it of and on for the next two hours, till I cant see the water on the tube.(hopefully)
