  #41 (permalink)
Old April 2, 2013, 07:13 PM
SugarJ's Avatar
OK, so the screws they told you to use with the backplate are too long, and they probably bottom out before tightening down. If the 6mm ones are long enough to start in the threads while going through the backplate, use them.
Or run without the backplate.
  #42 (permalink)
Old April 2, 2013, 08:11 PM
KaptCrunch's Avatar
ah the mystery solved, screws to long @ gpu congrats on your water cooling adventure
  #43 (permalink)
Old April 3, 2013, 07:19 AM
LegendMask's Avatar
Yup, Im gonna try the backplate with the provided screws in the first. ofcourse Im gonna try to run it with the plate hopefully
oh yeah finally lol, even with all the hassle for my first time, it was still fun. Really glad about it, but damn this new hobby is gonna be expensive
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
  #44 (permalink)
Old April 3, 2013, 06:51 PM
ZZLEE's Avatar
Dazome and silver coil
Yes you need it
Silver oxide kills biological algae, yeast and the like.
don't need your loop to look like a pond.
so a definite buy.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #45 (permalink)
Old April 3, 2013, 07:08 PM
It's hard for things to grow if there is flow in my humble opinion... and I only speak from my own experience. I've never had an issue with things growing. Recently however I left my rig off for 2 weeks and there was things starting to grow on the cpu block and one of my vid card blocks. Both of which were reasonably easy to clean.
I have a solution for that problem when I work out of town and I'll simply keep the pump running and the computer off when I'm away. Silver coil can ruin nickel plated blocks from what I understand and the correct way to stop that is to use a dielectric union wired to a sacrificial anode like magnesium. It's the same way all our hot water tanks are protected from corroding too fast.
Mah Rig now
Mah Rig before
My stuff for sale.
  #46 (permalink)
Old April 3, 2013, 07:46 PM
LegendMask's Avatar
Im gonna be using silver coil, I havent received it yet since CanadaPost screwed my shipment rout and its being delayed, but one more day is not a big deal
MSI GeForce GTX 560 Ti unstable Grennum Troubleshooting 14 June 11, 2011 12:15 PM
Unstable i7 920 @ stock speed... Charloz24 Troubleshooting 15 April 16, 2010 07:42 AM
Once stable OC is now unstable? Fenrise Overclocking, Tweaking and Benchmarking 2 September 2, 2009 03:49 PM
Unstable i7 920 System NightRain CPU's and Motherboards 2 April 9, 2009 06:54 PM
BIOSHOCK PC - An Unstable P.O.C. ? DarKStar Troubleshooting 8 July 30, 2008 08:27 PM
